TPI Heater Hose Diagram (Picture)
1 Post
Car: 1990 Jeep YJ
Engine: 70's 350 w/87 Z TPI-MAP Conversion
Transmission: Muncie SM 465 Granny Low 1st
Axle/Gears: 4:10 Gears in both axles
TPI Heater Hose Diagram for those how need it.
Thank you Eldon!
Thank you Eldon!
Reddragon88gta (04-01-2020)
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Re: TPI Heater Hose Diagram (Picture)
This is of no use to me but this might make a handy sticky for others....
Car: 1988 Camaro sports coupe
ayo can u get a hold of the wiring diagram(picture) cuz i did a swap from 305 TBI to a 5.7 TPI but cant get it to saty on and need to see a diagram pic this one is good but need the other for ground and stuff
Car: '89 Formula
Axle/Gears: 3:23
Transmission: Pro-built 700R4
I believe those are the different types of hose clamps reccomended by GM.
-Eldon
-Eldon
#5 is a bypass that keeps hot water from going thru the heater core unless you turn the heat on.
#1 appears to be hose clamps
#2 appears to be the hoses and pipes
#3 doesn't seem to exist
#4 is the hose that carries hot water thru the throttle body
Thanks, someone took out the diverter valve in my engine and I'm looking at this photo to figure out how he did it. I'm wondering where that hose at the top of the diverter goes. In the picture, it just seems to go towards the battery tray and into oblivion. And then there seems to be nothing going to the middle spout in the radiator in that photo.
I have a 92 camaro and I'm trying to put headers on. Do i need to take the emission stuff off?? If so how do I?
1992 Trans Am
05-10-2023 07:19 PM
Sanjay
08-12-2015 03:41 PM
