Throttle/Butterflies not closing fully
Old 12-09-2009, 09:54 AM
marmieej's Avatar
Car: 1988 IROC Camaro
Transmission: 700R
I have a problem getting my throttle or butterflies to close fully when I slowly release the gas pedal. The butterflies will stick slightly open. But, if I rev the engine up real quick and just let off the gas pedal, they will close.
Watching the linkage, it appears like the throttle spring is too weak to close the butterflies fully when letting off the gas pedal slowly.
Can I just replace this spring or is the problem something else entirely? If the former,, where can I get a new spring? I have searched and had no luck.
Any help is greatly appreciated!!!
Old 12-09-2009, 10:19 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Throttle/Butterflies not closing fully
dont know if you can take it apart (rivet)?
but you can always install a return spring. like on a carb.
also make sure it's not all nasty in back of the plates..(clean it up)
should close when clean..
Old 12-09-2009, 12:14 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
I repaired my sticking throttle body blades by removing the tb and cleaning the bores with some good carburetor cleaner and then hold the tb blades open and lightly sand the bores with some 400 grit sand paper until the blades no longer bind. worked wonders on mine. its been several years since I have done it and it still works like new
Old 12-09-2009, 03:43 PM
AC
AC's Avatar
Car: Used to drive a camaro
I did this:
Take TB off
Take butterfly plates off / out ( I believe they're are 2 screws each?)
They should slide out of the bar they're in
Take some green scotch brite and run around the OD of each plate lightly but enought to clean them off and take off any burrs / scratches
Clean the SH*T out of the innner bores, again running a little green scotch brite around the bores of the TB
Reassembled but only thread the butterfly plate bolts in halfway
Close the throttle body and they plates should center themselves in the bores and in the bar
Tighten bolts
Old 12-10-2009, 01:09 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by marmieej
The butterflies will stick slightly open. .....it appears like the throttle spring is too weak to close the butterflies fully when letting off the gas pedal slowly.
The fact that it closes when you hit it hard means there is nothing wrong with the spring tension.The problem is with the TB binding up somewhere
Check the butterfly shaft for slop on the hole where it goes through the TB housing also.
When it wears out of round with age ( common ) the vac pulls the butterflies off center so they bind up on the bore and not close fully back on the stop
If any noticible slop then you can get TB housing rebushed
Old 12-10-2009, 09:02 AM
uemf's Avatar
Car: '86 Firebird
Engine: '85 TPI on crate 350
Transmission: T-5 man
I'm betting it's the play in the butterfly shaft.
I just swapped in one from a doner car because mine had so much play.
I notice the most play in mine when I pushed the drivers side of the shaft towards the front of the car.
My idle is much more reliable now. sometimes it would idle at ~800 other times at 1500 with the original TB. A blip of the throttle and who knows where it would be.
Tony
p.s. I've never seen anyone sell a TB rebuild kit but there are a few guys that will rebuild it for you out there on the web, but you have to send it to them... (if anyone know different, I'd love to be able to go back to my original TB, it looks better )
Old 12-10-2009, 08:08 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The housing requires boring oversize so new shaft bushes can be fitted.
Some places will bore the TB out at the same time
http://cgi.ebay.com/ebaymotors/54mm-...Q5fAccessories
You send your old TB back for the core credit after you install rebuilt one;
no down time
Old 12-11-2009, 01:14 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Had this problem after I removed and cleaned my TB. A good couple shots of WD40 on the pivot shaft where it connects to the sides of the body fixed me right up.
Old 12-11-2009, 02:03 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Just wondering, how many miles are on your car? Maybe i should pull mine off and clean the crap out of it as some preventative maintenance.
Old 12-11-2009, 04:01 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If you don't know when it was last cleaned ; well worth the effort. Normally lottsa gunk in there
Reset IAC and TPS when finished
http://www.corvetteactioncenter.com/...and+Idle+Speed
Old 12-12-2009, 07:10 PM
jack harrison's Avatar
Car: 1987 pontiac trans-am
Engine: 350 tpi
Axle/Gears: 3;73 with eaton lsd
greese the tb spring up and check for exhust leaks! ive got an adjustable borla exhust and with the smallest holed plate in my throttle wouldnt close! must be something to do with vacum. i changed the plate and its never happened since.
Old 12-12-2009, 09:20 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by jack harrison
greese the tb spring up .
The spring is not the problem; it closes correctly if he snaps it shut fast.It is only on slow closing it binds up
Too much backpressure ; exh can't get out
Old 12-20-2009, 09:53 PM
Sandman22's Avatar
Car: 86 Trans Am
Glad to see it all worked out at least, I will keep it in mind if I have any sticking issues in the future.... Thanks much
Old 02-02-2013, 01:55 AM
franqc's Avatar
Glad I found this blog, I am having a big problem with TPI throttle sticking open, something about vacuum for sure. I see here a similar problem and it was exhaust!! Having a hard time trying to figure out what we where talking about?
Someone please elaborate for me if you can, Thanks Franqc.
Old 02-02-2013, 11:55 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
read post #5 , are you throttle blades sticking open or do you have a vacuum leak or both. A visual inspection and feeling play in the throttle shaft by moving the lever to check for play would be a start.
Old 02-02-2013, 01:17 PM
franqc's Avatar
Thanks for your reply, I have checked the TB and butterflys no problem there. How do I check for vacuum leaks?? I can actually watch as the throttle retracts when I turn off the engine!! Thanks once again.
Old 02-02-2013, 01:22 PM
Engine: Lb9
Transmission: M20
you throttle blades are not fully closing until you turn off your engine ? If thats the case the return spring is weak or the throttle shaft is worn or sticking.
Old 02-02-2013, 01:39 PM
franqc's Avatar
Spring is fine, had the whole thing off the car, closes like a rat trap with engine off, but sometime is causing it to stay open with the engine running, has to be another cause
Old 02-02-2013, 01:41 PM
franqc's Avatar
I noticed some small hairline cracks around the headers, would this contribute!!!!
Old 02-02-2013, 01:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Old 02-02-2013, 01:57 PM
franqc's Avatar
I have examined it from every angle, have taking it off, no play or slop and it snaps shut, but not with the engine running!
Old 02-02-2013, 04:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, because the shaft is worn.
It's not round anymore and the vacuum sucking on the back side of it at idle keeps it from closing. It'll close just fine when there's no vacuum, and you won't notice any play.
Old 02-02-2013, 04:53 PM
Engine: Lb9
Transmission: M20
Please do not pm me asking me to call you. The information is all provided for what you need to look for.
Old 02-02-2013, 09:45 PM
franqc's Avatar
Sorry if I was out of line, I was working on the car and needed to get it finished before dark! My bad.
Old 02-02-2013, 09:49 PM
Engine: Lb9
Transmission: M20
Old 02-02-2013, 10:03 PM
franqc's Avatar
I see some advertised @ 52 and 54 mm, is it marked on them? or is it by the year and model?
Old 02-02-2013, 10:20 PM
Engine: Lb9
Transmission: M20
stock is 48mm, you can have yours bored to 52mm and or rebushed. aftermarket you can get 54mm and 58mm. The linkage style you need is 89-92. This is a little large but is a good price but you need to buy a ACCEL 74192.
http://www.ebay.com/itm/New-ACCEL-TP...c5bff6&vxp=mtr
http://www.autozone.com/autozone/par...96537&cmpid=cj
Old 02-02-2013, 10:27 PM
Engine: Lb9
Transmission: M20
or this
http://www.summitracing.com/parts/sum-227705/overview/
or place a ad in the wanted classified section
Old 02-02-2013, 10:37 PM
franqc's Avatar
Sweet great deal and brand new! Thanks, can't go wrong with this. Thanks once again.
Old 02-02-2013, 10:40 PM
Engine: Lb9
Transmission: M20
I believe the second one will either fit both linkage styles if not it will come with 2 levers one for 85-88 and one for 89-92. The application listing shows all years though. The throttle maybe alot stiffer with this throttlebody I know bbk's atleast are a pretty stiff return spring.
Old 02-02-2013, 10:49 PM
franqc's Avatar
So the two eye ports and all the hardware bolt on to TB listing you sent me!
Old 02-02-2013, 11:01 PM
Engine: Lb9
Transmission: M20
a new throttle body will come with the gaskets you will need to swap over your coolant/iac housing. It is common for the bolts to break when removing the lower iac plate soaking it down with pb blaster helps remove.
Old 02-02-2013, 11:18 PM
franqc's Avatar
Great stuff, I am all over it.
Old 02-04-2013, 03:02 PM
franqc's Avatar
OK, I finally got my throttle to close and eliminate my high idle, It was mentioned above but not fully agreed upon! This is what I think happens, as I said I examined my TB from every point of view and found nothing out of the norm. What I did find was some small cracks in my headers! So I set about repairing them with exhaust repair, let it dry, and presto, every worked as it should. This is what I think happens, when there is an exhaust leak above the O2 sensor the car takes in air and passes it down to the sensor which picks it up and tries to compensate with the IAC, thus making the car idle higher than norm! This is why it only happens when the car is running but when its not the plates close freely!! Sometimes wear might be attributed in other cases, but not in my mine, my car is running as it should!
Let me know if this is a possible scenario.
Old 02-04-2013, 03:08 PM
Engine: Lb9
Transmission: M20
if there is a exhaust leak bye the o2 sensor the o2 sensor reading will be false. The o2 will think the engine is running lean due to the additional air and will run the engine rich to compensate.
Old 02-04-2013, 04:04 PM
franqc's Avatar
Would this cause the throttle to stay open a little at idle?
Old 02-04-2013, 04:09 PM
Engine: Lb9
Transmission: M20
No it wouldn't keep the throttle blades open. The ecm controls target idle speed based off coolant temperature and the park neutral switch selection. The iac is a controlled vacuum leak that the ecm uses to control the idle speed through the passage in the center of the throttle body.
Old 02-04-2013, 04:17 PM
franqc's Avatar
Wow thanks, so it was just coincidence that my problem went away after I repaired the leak! Would the IAC letting more air into the plenum cause the blades to stay open a smidge!
Old 02-04-2013, 04:20 PM
Engine: Lb9
Transmission: M20
I have no idea why your throttle blades were open a little.
Old 07-30-2013, 02:58 PM
franqc's Avatar
Thanks so much, you were right, got if fixed. But came back from vacation and I have another problem, when I start the car in the mornings from cold it runs high (like a choke) @ about 1000 rpm which is normal. It use to drop after a blocks but now it stays high! the only way I can get it to normal idle is to turn off the engine and restart it, happens every time, very frustrating! Any ideas as to the problem? Thanks once again. Franqc
Old 08-02-2013, 08:02 PM
devilschariot's Avatar
Engine: 305 tpi
Pop the cap on your idle adjust screw on your tb, back out the screw. The butterfly is connected to an arm that hits this screw. Does your butterfly go back as you back out the screw?
If a gap opens up between the valve lever arm and the screw end as you back that screw out, start your car and push in that arm lever towards the screw end to lower idle. Does idle stay down with the lever arm touching the screw end? Does the arm go down but idle remain the same or higher?
Keep in mind, by down, I mean pushing the butterfly lever towards the drivers seat.
Old 08-02-2013, 08:09 PM
  #42
Engine: 305 tpi
Whats the lowest your idle will get by backing out the adjustment screw is basically my question. And if you can keep backing it out but the idle still stays high, does closing the butterfly with your hand lower the idle?
hectre13
Car Audio
26
03-03-2022 05:38 PM
Linson
09-25-2021 07:55 PM
Pac J
05-17-2020 10:44 AM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
Vincent135
09-28-2015 10:50 PM
Quick Reply: Throttle/Butterflies not closing fully
