tpi and lt1 air foil
Old 03-16-2010, 12:59 AM
Brad5117's Avatar
do these actually work ?? i dont rele want to spend 20 bux on something i wont be able to tell is there , it says better throttle response and 5-10 hp gain ??
Old 03-16-2010, 01:07 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: tpi and lt1 air foil
I would probably say they'd work if you had other mods, such as an aftermarket intake, headers and such.... on a stock, probably not the desire you'd like... but then again maybe they do work... I think it prevents turbulence or something ... don't remember...
Old 03-16-2010, 01:22 AM
Brad5117's Avatar
why would u need other mods like runners and etc ?? if it moves more air it will gain horse power even if there where no other mods right ?
Old 03-16-2010, 01:49 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
an air foil I don't think moves more air, it settles it down ... my train of thought is, how can a 60 dollar part compete with a 300 dollars part such as headers or an intake manifold... I think you would see the numbers it advertises if you allow it to do its job... I don't think you'll see a 5 horsepower gain, but like I said before, perhaps you will... .. lets wait and see what other members who have used this device have to say...
Old 03-16-2010, 07:04 AM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
It reduces turbulence and makes it more smooth for the air to enter the throttle body. If your car is completely stock, all you will get is better throttle response. I use the piece from TPIS and noticed a big difference but also I'm quite far from stock. Don't expect huge gains if you are stock or have a 305, try headers and exhaust, AFPR, or intake and runners instead.
Old 03-17-2010, 08:41 AM
Pocket's Avatar
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
On a flow bench, the foil increases flow
https://www.thirdgen.org/forums/alte...ctor-info.html
On a dyno, no power is made from either TPI or LT1. Spend your money elsewhere
Old 03-17-2010, 08:59 AM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
True, everything I have ever seen shows increased airflow due to less turbulance in front of the throttle body. However when I installed one on my car I felt no difference and there was no difference in my 1/4 mile times either (bone stock L98 at this time), a SLP cold-air fixed that though... I think my airfoil has been laying in my toolbox or somthing since lol.
Old 03-17-2010, 10:02 AM
S10Wildside's Avatar
The effect of the air foil is increased cfm (more air incoming than without the air foil). More air means you should add more fuel (most don't and there's the issue).
TPIS commonly sells the airfoil with an adjustable fuel pressure regulator to avoid ECM calibration rework.
Many others have copied the TPIS air foil and sell it alone without an adjustable fuel pressure regulator. Don't expect much gain out of an air foil alone (without adding fuel).
Regardless, even on a stock engine, some would consider the small gains to be worth the money spent. Obviously if you're looking for big gains, focus on exhaust, heads, and/or cam.
Vintageracer
01-10-2020 05:33 PM
midge54
12-27-2019 04:14 PM
theurge
08-21-2015 12:46 PM
Street Lethal
08-13-2015 08:28 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: tpi and lt1 air foil
