350 tpi build
Old 03-31-2010, 10:40 PM
transamkid86's Avatar
350 tpi build
so i have a 86 t/a that has a 305 tpi in it so i got a 350tpi from a 91 t/a so i plan on rebuilding it but i have no idea if i should just get new pistons and everything else i really dont want to spend a lot of$$$$$$ but i really dont want to get alot of hp that i have to change the rear and all that other good stuff (well at least not right now) so i need some ideas if i should see if i can make a a 355 or something since maybe i will be changeing pistons and all thanks for the help in advance
Old 03-31-2010, 11:04 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: 350 tpi build
the only reason for boring is to make the cylinder surface new. if there is little cylinder wear or grooves just hone it, but if there is little or no wear i would leave it alone.
Old 03-31-2010, 11:11 PM
Re: 350 tpi build
so do you think a cheap 300$ rebuild kit from summit would be good? and without doing alot to the bottom end should i just maybe get a cam and some nice rockers and springs to just give it a little extra kick?
Old 03-31-2010, 11:20 PM
Re: 350 tpi build
yes. make sure the cam is ok for injected engines. you may want to hone and re-ring if you want to make more power.
Old 03-31-2010, 11:29 PM
Re: 350 tpi build
yea once i get the engine apart its goin to go to the shop to get cleaned up.. its just been raining down here all week. so i couldnt get the engine on the stand.
Out-Cast
08-17-2015 10:57 AM
Jlanz55
08-17-2015 07:15 AM
bamaboy0323
08-15-2015 07:20 AM
wruiz
08-13-2015 09:07 PM
gta power
08-13-2015 06:15 AM
Quick Reply: 350 tpi build
