Idle Air Control Valve Making Loud Racket What Does This Mean?
Old 05-19-2010, 06:56 PM
Slowridr's Avatar
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
First hot day I had my car out, GTA Vert w/ 5.7 TPI. Things started off good but then the car started running hot.
I was running down some issues with my fans that quit working. Did the diagnostic per the service manual and my fans are indeed dead. Both died which seems very odd to me. But during the process I had to ground my ALDL as if I were searching for trouble codes. When I did this I heard a clicking sound. It was a rapid successive clicking. Searched around and finally just unplugged my IAC and it stoped. I checked to see if it was plugged in properly and yes it was.
Turned off ignition plugged it back up turned ignition on (didnt crank up car) as if checking for trouble codes and clicking started again.
I never noticed this before. Is this normal or should I be ordering a new IAC valve?
Old 05-21-2010, 05:10 AM
Pat Hall's Avatar
Re: Idle Air Control Valve Making Loud Racket What Does This Mean?
Perfectly normal. Whenever you jump the A-B terminals at the ALDL and turn the key on, your IAC motor will click like that indefinitely. Whenever you turn your ignition key on without being in diagnostic mode, the IAC will run until the pintle is all the way seated, then it'll stop, but when you have the A-B terminals jumpered, it just keeps running, even after it's all the way closed. The reason it does that in diagnostic mode is so you can adjust the minimum idle speed screw on the throttle body. If you read the tech article here on how to reset the IAC and adjust minimum idle speed, it explains the whole deal.
Old 05-21-2010, 06:33 AM
Slowridr's Avatar
Perfect explaination! Thanks.
Old 05-22-2010, 08:20 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
I was glad to come across this post because I recently found out that a battery drain that would completely drain the battery in 4-5 days was being caused by the IAC, or so I think. With the key not even in the ignition and everything turned off, I could hear what sounded like voltage being applied to the IAC motor or the pintle going back and forth. I ordered a new IAC, but now I'm not sure whether its the IAC or my ECM? Any thoughts or ideas? And were you having battery drain issues also?
Old 05-22-2010, 09:40 PM
Slowridr's Avatar
Never had any problem with power drain. Hopefully one of the other guys will chime in.
Old 04-26-2015, 10:16 AM
valo2005's Avatar
Hi, does anyone know a solution to this problem. I am experiencing exactly the same (Ford Focus 2.0 2005) thanks!!!
specialized
06-18-2022 09:26 AM
theshackle
09-17-2020 08:26 AM
db057
08-22-2015 08:17 PM
mustangman65_79
08-11-2015 03:17 PM
bryan623
08-10-2015 11:33 AM
Quick Reply: Idle Air Control Valve Making Loud Racket What Does This Mean?
