'88 IROC 5.7 TPI swap into a TBI '88-'97 Chevy truck HELP - Third Generation F-Body Message Boards
Sponsored by South Bay Fuel Injectors
Click Here
Thread Tools Search this Thread
Old 10-10-2010, 08:53 PM   #1
Car: 1988 Iroc Z
Engine: 5.7 TPI
Axle/Gears: Stock gears.. disk posi
So I wrecked my '88 Iroc Z but I'm in the process of buying a 1988-1997 Chevy/GMC truck. My engine is still in great conditions and my plans are to swap it into a truck of these years..
I love being under cars and hoods figuring out what's wrong and fixing things myself. I have not done an engine swap yet but am ready for the challenge that awaits me.
Anyways the truck that I'm looking to get (1995 1500 z71) has a 5.7 TBI so I need to know the how I go about with the swap. My 5.7 TPI is lifted on a hoist rite now just waiting to get put into a truck.
Do I save the wiring harness and computer from my camaro? Any special adapters I need to find. I know I am probably going to fabricate my own motor mounts and such but I mean all this is fun to me..
Any information and insight will be very helpful.
If anyone has done a swap like this I would like to know how your swap turned out.. Was it worth it??
All your contributions are greatly appreciated!
Thanks in advance,
Skuanto
skuanto is offline vBGarage Page   Reply With Quote
Old 10-10-2010, 09:28 PM   #2
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: L79
Axle/Gears: 3.42 Auburn Posi
Re: '88 IROC 5.7 TPI swap into a TBI '88-'97 Chevy truck HELP
You'll want to keep the ECM and harness for sure. But couldn't you just put the TPI on it instead of pulling the motor?
RubberDucky is offline vBGarage Page   Reply With Quote
Old 10-10-2010, 10:14 PM   #3
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
yea you need to save all electronics that went with the tpi all the wires, the main harness, the ecm what rubberducky said makes sense but you would need all the stuff that makes tpi work so unless you have a serious problem with the camaros block just swap it. (while you have the block out you may also want to think about changing valve seals and rings if you havent yet maby even have the cylenders honoed or 30d over and maby get yourself a nice cam cranes 2032 powermax cam gets bad rep but its a nice boost if your staying stock)
Red 87 GTA is offline vBGarage Page   Reply With Quote
Old 10-11-2010, 03:21 PM   #4
Car: 1988 Iroc Z
Engine: 5.7 TPI
Quote:
Ok I got harness and ECM saved and ready. When I switch ecm's does that mean the truck will now THINK it's a camaro?
Old 10-11-2010, 03:27 PM   #5
Car: 1988 Iroc Z
Engine: 5.7 TPI
Quote:
Thanks good info to know but the trucks I'm looking at have TBI and are high mileage vehicles (160-220k miles) and my camaro engine only had about 72k original miles so I was thinking of just switching the whole thing.. However I'm still going to take apart the engine and make sure everything is crisp and give it new seals and gaskets.
I think I have an idea of how to go about this now bit I'm sure as I'm going through the actual process I will be encountering problems of all sorts so when the swap goes down I'll be posting more specific questions but thanks for all help contributed so far
Old 10-11-2010, 08:18 PM   #6
if you have questions about how to go about the gaskets seals and stuff just ask (valve seals are extremely difficult to do so unless you have done them before i would get someone who knows how to do it) but i will be here to help or jive advise oh and yes if you change ecms your truck will think its a 5.7 liter v8 tpi it will run the same as it did in the camaro but in truth it never did know it was a camaro so you should not have a problem
Old 10-11-2010, 09:39 PM   #7
Car: 92 Z-28
Engine: Tuned Port 305
Transmission: 5speed
Thanks in advance,
Skuanto
that engine will blolt right into your truck. the only the only things you have to really mess with is the wiring and most likely the upper rad hose. if you plan to keep the AC if the compressor is mounted in a different location on your tpi engine than it was on the truck engine you may need custom AC lines. and you will have to build some kind of air intake system. thats really all i can think of.. i think the tpi engine will work well in a pickup because of it's low end torque so this sounds like a great idea to me
86 toy is offline vBGarage Page   Reply With Quote
Old 10-12-2010, 08:52 AM   #8
Car: check
Engine: check
Transmission: check
Anyways the truck that I'm looking to get (1995 1500 z71) has a 5.7 TBI so I need to ...
Thanks in advance,
Skuanto
If that truck has an auto tranny it will be an 'E' trans. Which requires a controller. The stock truck PCM can be used as a controller while piggy-backing the MAF Camaro ECM to run the engine.
If it is a stick tranny, then it will have an ECM that can be replaced by the Camaro ECM. Along with the harness (of course).
RBob.
RBob is offline vBGarage Page   Reply With Quote
Old 01-31-2011, 08:10 PM   #9
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
Thanks in advance,
Skuanto
I may be a little late here, where are you at with this? I have alread done this. PM me a Personal email and I will send you what I have on it
P.S. I tried to use the stock PCM. best to go with the "411 LS1 ECM, you can get more support and help for it. AND I REPETE DO NOT TRY TO USE THE VORTEC ECM. been there donethat, I wasted $400 for a bad program.
Tinbender59 is offline vBGarage Page   Reply With Quote
Old 02-04-2011, 11:42 AM   #10
JDud's Avatar
I think the fuel pressure on the TPI is higher than the TBI also, may need to swap fuel pumps/regulators...but my memory is a bit foggy so double check that.
JDud is offline vBGarage Page   Reply With Quote
Old 02-06-2011, 02:32 AM   #11
Quote:
Yes! you are correct he will have to put an inline pump on it TPI needs minimum of 60 psi, although it regulates down to 45 with vacuum and 53 on WOT
Old 01-13-2014, 10:45 AM   #12
im lookin to do a tbi to tpi conversion on my 1993 gmc suburban 1500.i always been a Camaro guy but I got 5 kids so the suburban is needed for sure.lol but anyway I was thinking bout putting together a tpi off an ol Camaro.i know there are changes here and there on tpi system over the years and I know my parts mainly need to be from the same year tpi system.has anyone done this ? an there seems to be difference of opinion on weather my factory computer can be reprogrammed to run the tpi.looking for some opinions on this matter
Josh Barrett is offline vBGarage Page   Reply With Quote
Old 01-13-2014, 06:24 PM   #13
Quote:
read this http://forum.gmtruckcentral.com/show...988-TBI-to-TPI
Thread Thread Starter Forum Replies Last Post
[IL] 1990 Camaro RS Modified Frozer!!! Camaros for Sale 25 08-17-2016 08:37 PM
5.3 or 5.7 not sure which route to take? jharrison5 Engine Swap 5 08-19-2015 06:53 PM
open element/air cleaner wruiz TPI 15 08-13-2015 10:07 PM
Making the non functional Hood air vents, into functional. mustangman65_79 Body 3 08-11-2015 04:17 PM
Tpi tunning issue squiggy2 TPI 4 08-09-2015 10:30 PM
Go Back   Third Generation F-Body Message Boards >
Tags
1988, 57, 88, camaro, chevy, ecm, iroc, motor, port, putting, swap, tbi, tpi, truck, tuned
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
