Advice needed with TPI intake component matching
Car: 1938 Chevy 2 dr Sedan
Engine: Dart400 AFR190 TPIS ZZ409 Big Mouth
Transmission: Gearstar 700R4 level 4
Axle/Gears: Moser 12bolt-Det Trac loc 3:42
Need advise on TPI components I have the following parts.
AFR 190 non EGR heads a 1990 TPIS LTR and manifold with EGR plate installed. Early 1985/86 TB and plennum.
Will the early plennum and TB PCV system work with the later intake manifold is there a difference in PCV passages for the early 1985 and later 1990 TPI manifolds?
1992rs/ss
05-19-2020 07:02 PM
