1988 IROC dies everytime I put the car in D or Reverse
Old 07-20-2011, 10:17 AM
SEBLS1's Avatar
Im not sure where to post this at. I posted in Engine Forum & then saw there is a TPI Forum.
Im new to the board. But a lover of the 3rd gens. I have been restoring my 1988 IROC for the past 5 years & bringing it back to life. Bought the car for a $1000 as a roller with the motor & trans out of it & the Engine harness ripped out.
Now after about $4000 in labor & parts the car runs. But doesnt run great! The motor was completely rebuilt & ordered new Engine Harness from Painless & had it installed by Painless Wiring in Fort Worth along with having the injectors flowed & cleaned & also with new fuel pump & flushed the stock gas tank out of all the junk in it from sitting for almost 6 years now
Really want to get this beauty back on the road & use it as a daily driver. Any tips would be appreciated. I am located in Dallas if anyone knows a TPI guru in these parts
Old 07-20-2011, 11:21 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: 1988 IROC dies everytime I put the car in D or Reverse
its ideling to low when you put it in gear it stalls out
Old 07-20-2011, 11:43 AM
brewer1862's Avatar
Car: 1990 rs, 1989 rs
Engine: 383 blueprint crate, 305 tbi
Transmission: 700r4, t56
Axle/Gears: 3.73, 3.23
on my 90 rs with 305 tbi it was doing that for a while, checked the fuel pump, fuel filter, spark plugs, wires. then took off my distributor cap, and the inside of my cap was all melted, changed the cap, then it ran fine. maybe thats your problem?
Old 07-20-2011, 11:49 AM
SEBLS1's Avatar
I will give it a look see, This motor was just put in. But all the parts on it have been sitting for 5 plus years IE: like the runners & intake & Dist itself. I think the cap is new though.
Evilmoked94 what can I do to keep the motor idle higher when I put the car in gear
Old 07-20-2011, 01:06 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
may need to adjust the IAC
Old 07-20-2011, 01:18 PM
SEBLS1's Avatar
Ju got off the phone with Painless and the Guy who did the wiring and it has all new rotor and cap with wires and sensors! He suggested bring the idle up and run some high octane through it and said the these injectors have a tendency to lock up.
Old 07-20-2011, 01:21 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
when injectors are flowed or new they are very prone to seizing up just run some injector cleaner and check you idle maybe bump it up some
Old 07-20-2011, 01:43 PM
Engine: L31 350
agree or recheck that he set your TPS correctly.
IAC is idle air control
and TPS is throttle positioning sensor
Old 07-20-2011, 02:29 PM
SEBLS1's Avatar
This all makes sense & same advice he gave me. Just wanted to confirm it & get any other ideas of where I should check. He said it has a new pick up coil also too!
Old 07-20-2011, 02:58 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
What RPM is it idling at?
Old 07-21-2011, 10:56 AM
SEBLS1's Avatar
It barely will idle at all. Car feels solid under load. But I think you guys are right. I need to bring the idle up
Old 07-22-2011, 09:15 AM
brewer1862's Avatar
yeah i had that problem with my tbi 305 when i first bought it, replaced my tps, and it ran fine, just had to adjust it to get it to idle right.
jhawkeye
05-25-2022 06:33 PM
Wade787b
09-29-2015 01:15 PM
mustangman65_79
08-11-2015 03:17 PM
hokis
08-09-2015 03:57 PM
Quick Reply: 1988 IROC dies everytime I put the car in D or Reverse
