Pcv valve ???
1 Post
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
Pcv valve ???
Ok so I noticed that the tpi has two Pcv valves I'm installing pre 86 edelbrock valve covers an it only has one port for the Pcv an one big one for the oil fill plug is it ok to just use one Pcv or do I need two???
1 Post
Re: Pcv valve ???
Hmmmm weird cause when i disassembled my stock 350 today to pull the motor out i took two pcv valves off one that goes into the intake manifold an one that was hooked up to the throttle body
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Pcv valve ???
One is a PCV valve, one is an elbow, unless someone has done something dumb.
1 Post
Re: Pcv valve ???
Yea sO i think it was right do i need the elbow or could i just block it off
Engine: 383 Carb
Transmission: 4L60
Re: Pcv valve ???
You need the elbow, or at least something on that side to let clean air in. The factory setup is the cleanest possible way to do it.
1 Post
Re: Pcv valve ???
Ok so ill just get a breather an see if that will work i then have to block it off from the throttle body
1 Post
Re: Pcv valve ???
Ok so what you are saying is to get a breather woth a vac port to hook up to the throttle body an also use that as a oil fill this will be on the passenger side of the motor an for the drivers side it will be the pcv valve hooked up to manifold vac port right under the fuel rail on the drivers side of the intake manifold
tyeo098
11-30-2015 06:27 PM
355tpipickup
09-13-2015 11:35 PM
