Tweaking my L98 TPI
Tweaking my L98 TPI
Hay guys I am trying to squeeze out as much power as I can from my stock tpi someone told me to Chang my timing it still stock I have done
Holly 58mm
ported runners and plentom
lt1 injectors
jet chip for a 88 tpi made in1993 (found in junkyard car)
165° thermostat
No air pump(smog pump)
Shorty headers with slp. Loud mouth exhaust
T56 swap
plus a full bmr tubular suspension front to rear and a 2 inch drop
Any ides on what I can do cheep/free to put some more power down be for I dyno
Holly 58mm
lt1 injectors
165° thermostat
T56 swap
Re: Tweaking my L98 TPI
Holly 58mm
lt1 injectors
jet chip from 1993holiday (found in junkyard car)
165° thermostat
T56 swap
Holly 58mm
lt1 injectors
165° thermostat
T56 swap
Ok I fixed it I don't know how it got there smart phone ya right anyway
no cam. Yet I have a LT4 hot cam I was told it mite work I don't know yet
what is int? And blm? I probable feel dumb after you tell me so lost
It is out of a 88 350 tpi the chip was madeo in 93 found in a 88 iroc
Engine: 4++,350 & 305 CIs
What year is your car? and is it a factory 350 car??
Ofcourse a custom tune is the way to go buuut.
Take out the Jet chip and install the factory 350 chip. You can bump your timing to 10* maybe more. If you know what to listen too, unhook the knock sensor.
Use 93 octane. Bump your fuel psi to 50ish.
Do all this at the track or the dyno to find the sweet spots.
There are tons of lil things you can do.
NBrehm
08-25-2015 11:49 PM
Sanjay
08-12-2015 03:41 PM
