91 5.7 TPI crappy mpg and no idle, Help!!
Car: 91 Formula
OK, i just bought this 91 formula tpi 350 car. Engine is stock, has been getting 14 mpg mixed(which is still bad for this car). The PO had adjusted idle high because once it warms up, it will stall out in drive at a stop. Ive adjusted idle down some, SES is intermittent and i havent had a chance to hook up a scan tool. I can smell fuel when i shut the car off. Fuel press reg i disconnected the vac line to intake and no fuel leaked out, but i can smell fuel in vac line going to booster. I cant find any vac leaks and hoses are new. I pulled front drivers side spark plug and it looked dry, but like it was hot, but temp stays around170-180 driving. Other than my rattling cats(which are being taken care of next week), why the poor idle and fuel smell? injectors?
Re: 91 5.7 TPI crappy mpg and no idle, Help!!
ohm your injectors when the car is warm. If they are the original multi-tech I would have them hit the first trash can.
these are the way to go
http://www.southbayfuelinjectors.com...7&product=1502
Car: 91 Formula
how do i check them? also, filled up today and put sea foam in the fuel, but did the math and i got 17.2 avg mixed driving. not too bad, but i still smell fuel, dont see leaks, and still stalls on occasion warm at a stop in drive.
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
if they are original I would almost be willing to bet you have at least one injector with an issue
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Your lockup converter may not be unlocking when coming to a stop. When that happens the car will usually stall. The torque converter lockup switch can go bad. I'm not sure how to check it without taking the pan off. Maybe another member has a procedure they can post. Not a common problem but can happen.
Car: 91 Formula
hmm, good things to check. yeah PO had moved idle higher and that worked, but ive brought it down and had to move it back up a bit.. hoping to have time in next day or so mess with it.
Car: 91 Formula
got it scanned. EGR code. should have known better. Gonna buy one and put it in.. hopefully then i can reset the idle back down and it no stall anymore!
Pinks and these are both Ford but it's design 2 Bosch(Pinks) vs. 3rd design Bosch(Yellow).
Here's something to watch:
Sanjay
08-12-2015 03:41 PM
