vortec heads l31 on l98 intake manifold??
Old 02-12-2013, 03:12 PM
Promobass's Avatar
hi friends. I'm from Russia, do not know much English, give advice!
I have two options-
1-vortec heads and l98 intake
2-vortec heads and lt1 intake
lt1 intake no channel cooling system and does not have holes for distributor.
l98 intake does not fit in the holes to mount the head unit.
I collect all the easier to start the engine?
thanks for the help friends!
Old 02-12-2013, 03:36 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: vortec heads l31 on l98 intake manifold??
You'll need an aftermarket intake to use the vortec heads.
Old 02-12-2013, 05:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
$400
https://sdparts.com/index.php?q=deta...-center/sd3816
then if you want the TPI to work you need these and probably some porting of parts
$330
http://www.summitracing.com/parts/sle-20004/overview/
Better option for overall performance with Vortec heads and a straight bolt on
$640
http://www.summitracing.com/parts/WND-7542/
http://www.summitracing.com/parts/HLY-534-186/
Vortec /HSR a popular combo
https://www.thirdgen.org/forums/alte...ck-vortec.html
https://www.thirdgen.org/forums/post...598-post4.html
https://www.thirdgen.org/forums/alte...gal-whats.html
Old 02-13-2013, 02:35 AM
Promobass's Avatar
Thank you friends, but the way I buy the intake manifold can not be considered. we have a very expensive delivery. price in Russia is $ 600-800. for the money there to carve a new collector from a single piece of aluminum. I'm looking for a way that would alter the existing sewers in my stock.
Old 02-13-2013, 02:43 AM
OK then take your intake to someone who can weld aluminum and have the manifold modified to bolt to the heads. That should work.
Old 02-13-2013, 02:50 AM
Promobass's Avatar
who either already remade? can have a photo?
Old 02-13-2013, 02:55 AM
Promobass's Avatar
http://www.drive2.ru/cars/chevrolet/...nne/promobass/
84z96L31vortec
08-20-2017 12:16 AM
theurge
08-21-2015 12:46 PM
Jake_92RS
08-11-2015 10:39 AM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: vortec heads l31 on l98 intake manifold??
