91 t/a 5.7
91 t/a 5.7
I have 91 t/a 5.7 car runs fine for bout 30 min shuts off? Replaced ECM . Distb, fuel psi is 43-47. Has 12 v and grounds are good . I can spray cleaner in throttle body and it will run until stop spray? What could it be? Thanks pete
Engine: 4++,350 & 305 CIs
Re: 91 t/a 5.7
Are the injs org to the car? If so, OHM test them cold and then when warm/hot.
Check coil out put.
Did u replace the complete dizzy? or ICM or pickup coil?
Check coil out put.
KO1
16
10-15-2015 05:00 PM
LT1Formula
10-08-2015 08:34 PM
