Fuel line feed/return o-rings
Old 08-19-2013, 06:25 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
The o-ring on the metal portion of the fuel lines where they connect to the rubber lines are looking pretty bad. What are the proper part number for this application?
Fuel line feed/return o-rings-bbp8srpl.jpg
Fuel line feed/return o-rings-bo1abeyl.jpg
I have found the following part numbers: 22514722 & 22516256. Do those look like the right ones?
Old 08-19-2013, 06:26 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Fuel line feed/return o-rings
Just get a box of assorted and use the one that fits.
Old 08-19-2013, 07:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Have to be special fuel rated O rings ; not the reg type found in the assorted ring kits
Originally Posted by 89fast5oh
The o-ring are looking pretty bad.
Can you cross reference your par # against the correct size required as listed in link ?
http://webpages.charter.net/khasting...uelsystem.html
Old 08-19-2013, 08:29 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
They cross over and measure out to 3/8" and 5/16" o-rings.
RockAuto shows the part # and size here:
http://www.rockauto.com/catalog/rafr...rttype=1000952
Even shows a picture and it looks like them. Just wanted to make sure that those are indeed the correct parts.
Now to see if my local NAPA can get these o-rings.
Old 08-19-2013, 09:23 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I work for the manufacturer that supplies engine management parts to NAPA. The part # you want is 2-18416.
Old 08-20-2013, 06:31 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I found the Dorman o-ring kit today at my local parts store. Part number 800-013
Fuel line feed/return o-rings-ivqr91wl.jpg
Old 09-04-2013, 06:41 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
deleted
Frozer!!!
01-19-2024 04:55 PM
theshackle
03-05-2017 06:37 PM
Andrew6.688
12-13-2015 10:59 AM
AkDrifted
08-17-2015 07:45 PM
Quick Reply: Fuel line feed/return o-rings
