warms up then dies...
Old 10-24-2013, 08:34 PM
89 formula TPI's Avatar
hey guys,
i have an 89 formula with 305 and TPI. the car runs GREAT when it's cold, acceleration is great, idles fine. but when it warms up after about 10-15 minutes it runs terrible, it loses ALL pick up and eventually when i hit the gas the car sputters so bad it dies. then it won't start up for a while til it cools off. thinking its running really rich but can't figure out why. fuel pressure seems fine
it's got new plugs, wires, coil, EGR valve, injectors, cap, rotor, antifreeze, oil, and coolant temp sensor.
any ideas? im at a loss...
Old 10-25-2013, 07:23 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: warms up then dies...
https://www.thirdgen.org/forums/tech...formation.html
Start by pulling the fault codes
https://www.thirdgen.org/forums/tech...s-dumbies.html
and tell us what they are
Old 11-04-2013, 12:44 PM
TronGod's Avatar
Car: 1990 Convertible Camaro IROC Z
I may have a similiar prob with my 305 TPI. It would start up and run for X amount of time.....then would do same thing as you describe. If I sprayed carb cleaner into the intake, car would fire up then die. If I let it sit for X amount of time, then it may/may not run. Per advice here, I checked fuel pressure and was good....so checked Injectors for resistance, and found several that were below recommended values.
I ordered injectors but have not had chance to replace yet....hoping that this will resolve the issue. At least, it is the next step. I started a thread for this as well....
Old 11-04-2013, 02:51 PM
nomind's Avatar
Car: 85 Trans Am
Engine: LB9
Transmission: Finally Fixed (T5)
I've seen ignition control modules cause the same problem when they get warm. YMMV.
tyeo098
11-30-2015 06:27 PM
HoosierinWA
10-07-2015 10:15 AM
thejimsterz28
09-30-2015 08:52 PM
mfp189
09-27-2015 09:25 AM
amcnellis
09-16-2015 04:16 PM
Quick Reply: warms up then dies...
