Where to find EGR Solenoid Valve
Old 11-29-2013, 09:35 AM
mwlockhart's Avatar
Help! I need a new EGR Vacuum Solenoid valve for our 1986 5.0 TPI IROC. Mine is leaking a bit in the closed position.
I cannot find one anywhere! I'll take any suggestion - has this part been discontinued and there is some other one that will work?
Old 11-29-2013, 12:42 PM
mwlockhart's Avatar
Re: Where to find EGR Solenoid Valve
I've been digging and it looks like the 1985-1990 corvette solenoid is exactly the same except for the mounting bracket. Does anyone know if these will work - the valve itself looks identical?
http://www.ecklerscorvette.com/corve...1985-1990.html
Amazon.com: 1986-1991 Corvette EGR Control Valve Relay Solenoid: Automotive Amazon.com: 1986-1991 Corvette EGR Control Valve Relay Solenoid: Automotive
Old 11-29-2013, 01:35 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I'm not certain, but I "think" those will work but the electrical connector is different.
Old 11-29-2013, 01:41 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
I've spent a bit of time figuring these solenoids out. I don't know exactly how yours specifically is supposed to function but I do know they are either normally open(sends vacuum thru with no power going to it) or normally closed(closed vacuum and the egr side venting). My speed density TPI is normally open, I replaced it with a Caddy solenoid. I think early MAF were the opposite, maybe. If yours is normally closed (unlike mine) then I believe a fbody TBI solenoid or an LT1 solenoid will work.
https://www.thirdgen.org/forums/tpi/...id-91-gta.html
There is a link to another thread in there that shows a bunch of info too.
Old 11-30-2013, 10:29 AM
mwlockhart's Avatar
Thanks for the info. After checking my 1986 GM Camaro shop manual, I found that the EGR Solenoid on my 5.0 TPI F body is NORMALLY OPEN PWM Solenoid.
I found the following article on Corvette EGR troubleshooting...
http://tech.corvettecentral.com/2012...egr-diagnosis/
...and it states that the 85-89 TPI also uses a NORMALLY OPEN solenoid. From this I and looking at the actual part, I'm 99.99% sure it will work, will have to figure out the mounting bracket but no big deal.
I also found that the 1985 Camaro TBI uses a NORMALLY CLOSED Solenoid so that would not work.
After all this, I went to GM Parts direct and entered the part number for my Camaro and it let me order the part. Seems to good to be true, I'm expecting that the Camaro Solenoid will never show up. Stay tuned....
Old 11-30-2013, 10:43 AM
Two things. Paulo is correct the connector is often different. Though the corvette one looks to be the weather pack design like your 86 should be. I made a pigtail to change mine. And two, there is no 1985 TBI camaro. They were still carb'd. Fbody TBI started in 88.
Old 02-28-2014, 09:14 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
What came of this?????
Old 02-28-2014, 10:05 AM
My 92 SD works correctly with the 94 Caddilac solenoid. I never dug up the answer for the MAF setups.
Old 02-28-2014, 12:20 PM
Neal301's Avatar
Car: 1986 IROC-Z/28
Engine: LB9 TPI
I just installed the Vette one this week and it works fine. I had to put the vette solenoid in the old Camaro bracket to mount it. Otherwise it is the same part in a different frame.
Old 02-28-2014, 12:51 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Thanks, I have an 88 GTA 5.7 TPI, original owner and I may have a problem with mine.
Still in the testing phase
Old 02-28-2014, 01:46 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Neal301. Which port on that solenoid did you connect to the EGR valve?
Old 02-28-2014, 02:00 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Old 03-01-2014, 10:15 AM
The port that vents goes to the egr. The port that blocks off when the other is venting goes to the TB. You may have to energize the solenoid to get it to vent.
Old 06-09-2014, 02:09 PM
89gta22's Avatar
Car: 1989 Trans Am GTA WS6
Engine: 5.7 350 TPI
Transmission: 700-R4 from Raptor
Lots of comments here about the LT1 solenoid however I was able to locate the following correct model year solenoids at Auto Parts Warehouse.
http://www.autopartswarehouse.com/sh.../firebird.html
Question I have is will the 89-92 8cyl 5.0 solenoid - AC Delco p#AC214339 work for my 1989 TPI 5.7? Does anyone know if 1.They have the same connector and 2. If there is any reason the 5.0 solenoid will not work on the 5.7?
Thanks!
Old 06-09-2014, 02:59 PM
I believe that is the TBI solenoid. I have tested it on my 92 and it doesn't work. The Lt1 works like it and does not work either. Use the 94 Cadillac or corvette solenoid mentioned earlier.
jklein337
09-19-2018 06:23 PM
Out-Cast
09-03-2015 09:05 PM
Out-Cast
08-17-2015 10:57 AM
THABADGUY
Brakes
08-11-2015 03:43 AM
Quick Reply: Where to find EGR Solenoid Valve
