Hard vacuum lines- replace with silicone hose?
Hi team thirdgen.
I'm replacing vacuum lines and I wonder if there is a need to replace the hard plastic lines- like the ones that run from the canister to the TB with hard lines? They are hard to find and expensive and I would like to replace with silicone type flexible hose.
Thoughts?
Thoughts?
Car: 91 formula
Engine: 350 tuned port. bolt ons
Car: 1987 Trans Am GTA
Engine: 5.0 TPI
Re: Hard vacuum lines- replace with silicone hose?
Iwas thinking the same thing... swapping the hard plastic vacuum lines that are located under the TPI plenum with regular silicone / rubber lines....
1 Post
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Thanks!
Bill
Is 3/8 the right size for all the vaccum lines? My mecahnic pulled the plenum off to change the fuel injectors, and the vaccum lines broke in multiple sections. I want to completely replace them with rubber or silicone hose, but I need to know the right size.
Thanks!
Bill
Thanks!
Bill
1 Post
I haven't been able to find ANY stock replacement vaccum lines online. If I could, I would be pursuing that option.
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
You can buy it by the roll at the parts store. going to be a combo of 5/16ths, and 3/8ths I would imagine.
I am in the same boat. I think I might have a vacuum leak so I am in the process of buying new check valves and hoses. I plan on replacing everything I can get my hands on with silicone thick walled rubber hoses and some new elbow/T tubes. Just need the inside diameter and stuffs. Looks like 3/8ths and 1/4 win....
I found a forum on a hot rod site talking about why you should get silicone over rubber. http://clubroadster.net/vb_forum/86-...ber-hoses.html is the link. I bought this kit
http://www.siliconeintakes.com/liqui...ose-p-592.html
and i will update once I get it. It comes with 4, 6, 8, and 10mm I/D silicone hose in 18, 12, 6, and 8ft lengths. The total kit costs 62$ or so with shipping. Choose USPS for shipping. SAVE THE POSTAL SERVICE!
1992 Trans Am
05-10-2023 07:19 PM
mdtoren
08-16-2015 05:45 PM
