what fuel pump is best?
Car: 86 z28 daily, 2 89 iroc-z's
Engine: sbc's
I have a stroked 305 (335) dart heads comp cam HSR intake with adjustable regulator and 24lb injectors. Gonna upgrade fuel pump and curious what others have run. I would like one to fit like factory but would change if one is highly recommend. Car is street car.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: what fuel pump is best?
I bought the best one NAPA had 6 years ago and all is still good. AND I sometimes have to settle for ethanol gas.
Take a look at the #2 post here:
https://www.thirdgen.org/forums/tech...fuel-pump.html
It has several links you could read up on if you haven't found these already.
Car: 86 IROC
Engine: 5.0 TPI
there seems to be some confusion as to what fuel pump to use. some go for one that pumps 10,000 LPM while others have a car that is stock. and their only concern is buying a quality stock replacement. be it a TPI car, or a TB set up. so the question is; whats the best stock replacement for a TPI car? or for a TB set up? most aren't building a 9 second drag car, theyre just trying to drive what they have on the street.SO lets keep it stock street driven cars for this question.
Car: 86 IROC
Engine: 5.0 TPI
Rusty, are you saying "a stroked 305, Dart heads, Comp Cam, HSR intake, adjustable regulator and 24lb injectors" is stock, or are you saying a Walbro is too much for stock? My post was suggesting two things, to read up on a few other threads that will help him make a decision, and, without saying it, a Walbro pump.
I can't see a 335, with good cam and heads, exceeding much more than a stockish Walbro could deliver, many have put out good times with built up 350's and 383's with the factory pump, and never had fuel starvation.
I think the big pumps are best suited for those maybe boosting, or spraying.
Heck, GM's had mechanical pumps on BBC's putting out 450 HP and near 600 FT/Lb of torque back in the day...same pump they used on a 250 HP smogger BBC.
Car: 86 IROC
Engine: 5.0 TPI
Agree for sure Rusty...I guess I was replying to your post about seperating needs.
The Walbro I'm referring to is about 60/70 plus 8 for it's screen...made in USA...and is a good choice (IMO) over a AC Delco made in China, Mexico, etc...I wasn't referring to the 255?l Walbro pump.
In effect, agreeing with your earlier reply
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
