Rough idle and low rpm part throttle stumble - I'm stumped
The car idles rougher than normal and there is a low rpm miss/stumble below about 2000 rpms. This started after my MSD distributor took a dump on me. It would barely turn over with the MSD in it and it ran terribly at all rpms. I put in a new GM Performance distributor that fixed the barely starting and driving problem, but that's when the idle and low rpm stumble problems started. The weird thing is that the car runs better with the ESC module unplugged. I put a new ESC in it and the problem remains. Here's what's been replaced: Distributor, knock sensor, ESC, and plugs. I've swapped out the cap, rotor, and ICM on the GM dizzy with known good units as well. The base timing is set a 6* and fuel pressure is good at 43 psi. I should also add that this isn't a stock engine. It has an SR intake, AFR heads, and Comp 280XFI. I've been running with this combo all summer and haven't had any issues until now. Any suggestions on what could be going on here?
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Rough idle and low rpm part throttle stumble - I'm stumped
Forgot to mention that, no stored codes and no cel. Maf is older, but was replaced a few years ago. I'll swap out the maf relays with some spares and see what happens. Now that you mention it I remember getting a maf burnoff circuit code about a month ago but it hasn't come back since and only showed up that one time.
Car: 86 IROC
Engine: 5.0 TPI
Thanks for the tip. I'll give the relays a try tomorrow if I can track some down locally. The maf and related relays being the issue makes sense because iirc, the ecm takes inputs from the maf up until only a certain point and then the ecm ignores it, correct? That would explain why it runs OK with more throttle input and at higher rpms. Forgive me if I got that totally wrong.
Car: 86 IROC
Engine: 5.0 TPI
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Was the msd in there while it was running well? Was your final tune around this time the dizzy was failing? I'm thinking tune since it runs ok when esc unplugged ....hook it up and try adjusting tables...or if you have tuning done, if you haven't already try to datalog and see what's going on at idle and 2k
Finally got it figured out! I datalogged it the other day and compared it to some old logs that I had. MAF values all seemed normal and nothing else really seemed out of whack. So on a hunch, I went ahead and checked the TDC mark on the dampener against the actual TDC and go figure, it was off quite a bit. So when I thought I was setting the base timing at 6* I was actually setting it at a lot more than that. I'm estimating it was at about 12-14*. It was strange that it wasn't audibly pinging and I got zero knock counts. This also would seem to explain why it ran better with the ESC module disconnected because with ESC unplugged, the ECM would pull timing, right? I'm kinda ticked that the dampener slipped because it's only a few thousand miles old and was a brand new GM part. But at least it's running like it should be again. With that, does anyone have any suggestions for a replacement dampener?
Car: 1990 Trans Am
Nice you figured it out!!!! Not for sure on timing pull with esc unplugged but it obviously goes into a default mode (maybe someone can explain)
but great news on fixing it!!!
I just have a stock replacement jegs brand dampner and does fine
theshackle
09-17-2020 08:26 AM
92camaroJoe
08-13-2015 06:07 AM
