Throttle Body & Vavle Cover Question
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Doing a swap and have a few questions - The two hoses that come out the pass side of the TB, Top one goes behind the motor and attaches to the brake booster? Correct?
Where does the lower hose go? Pass side valve cover grommet?
Also, What hose goes into the pass side breather hole on the valve cover and where does it come from?
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: Throttle Body & Vavle Cover Question
That top spout connects to the passenger side breather. Red circles are what need to be matched up.
The lower spout on the TB is for coolant, it connects to the heater control valve.
EDIT: Christ I'm losing it. Even just looking at the picture, that lower spout is vacuum.
Just a note, the pass side isn't a PCV valve, just a plastic elbow.
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
8Mike9 is correct that the passenger side is just the breather not the PCV. The PCV plugs into a barbed fitting just behind the drivers side runners on the lower intake. The brake booster connects to a barbed fitting on the drivers side back corner of the upper plenum.
As for the bottom port it is supposed to connect to the EVAP canister.
This may help
http://chevythunder.com/1985-86%205....%20diagram.gif
This may help
Car: 89 IROC
thanks for the help guys. MUCH APPRECIATED.
Motor has been apart for two years and memory is getting old.
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
For a Camaro, the evap can is on the driver's side. You should have a hose that loops a 180* turn to go under the TB to a hard plastic line to reach the evap can.
1992 Trans Am
05-10-2023 07:19 PM
mdtoren
08-16-2015 05:45 PM
