TPI with EGR manifold temps?
Old 10-27-2014, 09:28 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Looking for stock or near stock TPI manifold temps with EGR running.
When your engine is warmed up what is your manifold temp?
I'm running a HSR and the MAT temp is in the 140-160 range and I believe this is lower than stock. Any input is appreciated.
Old 10-27-2014, 11:44 PM
Kennerz's Avatar
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
Re: TPI with EGR manifold temps?
Actually, sounds about right. I noticed my TPI car was running arround 150 deg. in warm weather.
Old 10-28-2014, 05:32 AM
Car: 89 IROC
Engine: 6.8 HSR N2O
Thanks for the info. Do you recall how long it takes to get to that temp? Mine has to run for 20+ min and even then requires a shut down to heat soak.
Out-Cast
08-17-2015 10:57 AM
Sanjay
08-12-2015 03:41 PM
camaroken83
08-10-2015 11:35 AM
drathaar907
08-06-2015 04:20 PM
Quick Reply: TPI with EGR manifold temps?
