Fuel pump pressure question
Car: 89 Camaro RS
Engine: 2.8 (soon to be 350)
hey, needs a quick answer, fuel pump **** the bed in the maro, buying a new one, but the parts guy says it puts out 75 pounds of pressure, the right pressure is about 45? is the counter guy on glue? he says its the only one that comes up for an 89 camaro rs 2.8, what should i do? there is no adjuster on it. any advice would be great!
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Re: HSR Adjustable Fuel Pressure Regulator Failures.
-- Joe
Car: Cobra Kit Car
Engine: 350 HSR
Transmission: TKO 600
Axle/Gears: 3.31
75 psi is a normal pressure for a pump.
The injection system and their components, are based on 45 psi pressure, as an example, we can say that the injector capacities and performance is based on this nominal pressure of 45 psi.
Therefore that FPR try to maintain the nominal pressure of 45 psi, by regulating the pump pressure.
92camaroJoe
08-13-2015 06:07 AM
