350 tpi will start but won't stay on
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Dumb question but did you change the fuel pumps? TBI uses 13psi and tpi uses 43psi.
Car: 91 formula ws6
Transmission: 4l60E
That's why its a dumb question. How's it run when its running? What was changed? Any codes? The usual questions
Re: 350 tpi will start but won't stay on
Lol yea I'm new to this...well it fires right up ...and as it starts to idle it just cuts right off ...just changed the motor, ECM nd wiring harness nd fuel pump nd switch the battery from left side to the right side
Car: 91 formula ws6
Transmission: 4l60E
What year ecm? Speed density or maf system? What you describe is vats turning off fuel since it has no signal or wrong signal.
Car: 91 formula ws6
Transmission: 4l60E
First year. Look up vats wiring. You need it or bypass it in the chip. The wiring won't be in your dash harness but you could add it I think. If the donor car is available swap the dash harness and vats module. If not you'll have to get a chip written without vats
Car: 91 formula ws6
Transmission: 4l60E
Had to say since it starts and shuts right off I assume within 3 seconds?
Car: 91 formula ws6
Transmission: 4l60E
If the wiring is their from a donor is just swap dash harnesses. Steering column included. Read up on the vats before you choose
Car: 91 formula ws6
Transmission: 4l60E
Look up companies then to write a chip without vats. It'll be a day or so out but it'll prevent any further hassle I'd think
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
Are you getting any codes? When I installed new fuel pump after upgrading engine to 355cc, I had a code (56?) for low voltage to fuel pump.
Timing might be an issue; mine is 11 degrees cold start, not zero as the shop manual says.
Am about to reprogram LPROM, to keep cold engine from running rich. My spark plugs are fouling.
Car: 91 formula ws6
Transmission: 4l60E
Not the 89. I had that system swapped. It will kill the pump tho almost immediately. The fuel pump relay powers the pump for the initial cranking then the oil sensor switch kicks in
Car: 91 formula ws6
Transmission: 4l60E
Which if you read what I said I agreed. It doesn't power down the ecm which you sorta asked/mentioned. I have that diagram imbedded into my head as I spent a number of hours putting an 89tpi in my 91 TBI equipped car at one point.
Car: 91 formula ws6
Transmission: 4l60E
Ecm turn off the fuel would make you think that man. I'm not trying to pick a fight, that's counter productive to the OP. Also I wasn't clear in my response back. I referenced that the ops shuts down the ecm so I apologize
Car: 91 formula ws6
Transmission: 4l60E
I agree the ops very well could be the issue. That's why I love these forums, every single one of us has ran into an issue at some point so we all drop an idea.
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
idk a lot about the vats ... but i do know when i swapped from tbi 305 to carbed 350 before, i had (almost) the same problem pump would shut off from not seeing the oil pressure (put in a mech gauge). i would make it about a block. for sure, check the sending unit wires before going into all the vats trouble.
VATS and the Oil Pressure Switch are the more likely culprit.
The ECM primes the pump for a second or two when you turn the key to the RUN position. Which pressurizes the rails and makes starting easier. This is usually enough for the engine to run for several seconds even if the fuel pump isn't running.
I can't remember if VATS disables the injectors from the get go if the right key is not found, or if the injectors are temporarily enabled enough to start the engine.
Its been some time since I had a TPI car.
Car: 91 formula ws6
Transmission: 4l60E
It disables the fuel pump and starting system. He doesn't have the wiring for vats so the starting system wouldn't be disabled. Only pointing that out*
Summit sales a VATS bypass by Painless I think but I thought it was 90 and above.Oil pressure will do it but Vats will not run at all and it will give a code 46 but it has to be a 90 system I think.
Car: 91 formula ws6
Transmission: 4l60E
Vats started in 89. I have an 89 system and had to bypass it.
http://www.camarosource.ca/brochures...1989broch2.jpg
Timing is less likely to be your problem. Your car is starting, then shutting off. It usually indicates a fueling issue.
Well Imma order the " fix it security VATS bypass module "
And hopefully she works I'll post results after ....wish me luck 😁
http://m.ebay.com/itm/191421440383?nav=SEARCH
Car: 91 formula ws6
Transmission: 4l60E
Make sure you call them first and explain the swap you did. You do not have the wiring for vats and that may be a plug and play deal I.e; you may be stuck wiring the car for vats just to bypass it. Hate to say but you may have to just order a prom with vats removed.
Yea I made sure I called them 1st they told me since car is starting that I should only need a fuel bypass but I oreder both for only $55.00 ...just in case ...question , since I will be bypassing how can I make sure car is not east to take/steal ?? Can I still put alarm system with out it being another problem ?
Car: 91 formula ws6
Transmission: 4l60E
I agree. It is a easy unfortunately. Hell I made my bypass using the dimmer module and a resistor. Sad but it works and I was stuck at that time with my soldering kit. Made up a unit and dialed in the resistance and yea.... I'm curious how the fuel bypass works? Does it send a 60hz signal to the computer?
Ooh ok I'll figure out something ... detachable steering wheel like the guys in the Hondas or something lol ...
Sanjay
08-12-2015 03:41 PM
