Injectors no firing
Car: 1988 Trans Am GTA
Engine: 350ci 5.7L TPI
Injectors no firing
Sup everybody.
1988 Trans Am GTA 350 5.7L
A few days ago out of nowhere started to surge, then stalled and after a few cranks it would start again. My suspicion was that it was a fuel delivery issue; pump works, plenty of fuel pressure replaced the fuel filter, and after that it wouldn't start, well, it does for about 2 seconds...
After checking the spark and the ICA I squirted gas on the throttle and ran for a few seconds, did it again to check the injectors and 'viola' no pulsations. I checked the pick up coil on my MSD distributor and it had over 600ohms. I know is not the VATS, I have a VATS delete chip from PCMs for less.
What else could be causing the injectors to shut?
Re: Injectors no firing
Did you verify not firing (injector) with a noid light?...I guess a test light would work as well, but never tried it.
Yes sir, I used a test light.
Plus, you could hear and feel the ticking when they're where working.
Update.
No voltage to the injectors.
What exactly makes the injectors pulsate? Or could a faulty VATS shut down the I njectors even with a VATS delete chip?
There are two fuses INJ1 and INJ2, in the fuse panel, check them...
The injectors should always have voltage on them, then the ECM will ground one side to fire them.
Now, ohm the injectors out as well, could be a shorted coils in a few, which could cause the fuse to blow...iirc, they should all be around 16 or 18 ohms (search to verify)
If VATs was deleted properly and the car was fine, it should still be okay.
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
VATS may be disabled in the chip but an issue with the relay or a bad VATS module itself can still cause issues.
Ok guys...
So I whent to the junk yard today I got a pass key module just to rule out the VATS system. It still doing the same thing. So, ECM maybe?
I don't have my manual close by, but am going to go out on a limb here, and say there is nothing in the VAT's module or Vat's related...nor the ECM, that would turn voltage off to the injectors.
How were the fuses?
Voltage on both sides of them?
How were the fuses?
I thought I'd narrow aver urging down to the ECM. I replaced it this morning but still nothing. There is no voltage to the injectors when the ignition is on.
1 Post
Car: 1987 GTA
Engine: 383 HSR Procharged
Transmission: TKO600
Axle/Gears: Moser 9", 35 spline Wavetrac 3.89's
I would still test the injectors with a voltmeter along with the fuses to make sure you have voltage when you're supposed to have voltage. Just sounds so much like the FP relay is spent. Trying to find my wiring diagram.. Found these...
http://i56.photobucket.com/albums/g1...transbody1.gif
http://i56.photobucket.com/albums/g1...transbody2.gif
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Run your own wires to both sides of injectors to a 12v switched source fuse it off and it should fire right up.
As I mentioned before, and as the schematic sparks posted the link to:
https://www.thirdgen.org/forums/atta...ine_wiring.pdf
The ECM only grounds on side of the injectors to fire the bank.
The other side is always with voltage, when key is on.
So...my last time I'll ask, is there voltage off INJ1 and INJ2 fuses?
These wires (post fuses) go directly to the injectors.
I checked for the 3rd time. There is voltage to Inj1 and Inj2 with the key on.
Also, there's only voltage to the hot side with the ign on on the injector connectors. I thought both sides where supposed to have 12v and then the ECM would ground one...
1 Post
Car: 92 Firebird Convertible
Engine: 383 - First Fuel Injection TPI
Axle/Gears: 3:23
Look at the above post wiring schematic. With all of the injectors unplugged, voltage will be on one side only - if you leave any of them connected "backfeed" can show voltage on both sides - again study the above schematic.
Connect a noid light or a Radio Shack Led across any one of the injectors connectors - key off should see a dim light. Key on should be bright - indicating ECM is grounding the injector circuit.
Okay, I think you should see voltage on both sides, at least with just one connector unplugged...as I recall, both lights on the Noid light are lit, and one is "blinking" when turning the engine over/trying to start it...I'll verify both conditions (with DMM and noid light) later this afternoon, or tomorrow for you..I'm knee deep in my '42 Ford right now.
With just one injector clip unplugged, I have voltage on both side of the clip, assume since the injectors are in parallel, that's why.
I haven't had time to work on my car recently but here's an update... I replaced the ECM, I have voltage on D15 and D16 pin outs, checked the connectors and only the hot side has voltage, the other side is dead (no + or -). I know one side of the connectors go straight to the ECM, my question is, where does the other side go to? The schematics I've seen are not very clear. Also what gives the signal to the ECM to ground the injectors?
Ok people, this is my final diagnosis. THE ECM IS NOT GROUNDING THE INJECTORS, Everything else is fine, all I need to know is what's causing this.
Help please!!!
Help please!!!
Look at the wiring at the distributor. Especialy the purple/white wire at the icm. If the ecm isnt seeing a distributor reference pulse it will not pulse the injectors. You can still have spark but have a bad icm.
I took the ICM to autozone to have it checked and it was good. I Was thinking that it could be something with the distributor wiring, I have an MSD distributor with a MSD 6a ignition box, so the wiring is not stock but it had been working fine for about a year.
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
If the ECM is not grounding the injectors then check grounds for the ECM. When I pulled my engine, some grounds were so loose in the factory connectors it was nausiating. Check the grounds on the block (heads) That is the only thing I can think of. good luck
1 Post
Axle/Gears: 3:23
I've posted this before.
Brand new distributor had a bad ICM - took it to Auto Zone - tested good - made my own ICM testor with an extra coil and a spark plug. ICM would not fire the plug - so much for Auto Zone testing. Replaced the ICM - fired right up.
Go to these sites - lots of tips.
http://easyautodiagnostics.com/gm/4....-of-articles-1
http://easyautodiagnostics.com/gm/4....ed-icm-tests-1
Good Luck
Good Luck
She runs again!
Especial thanks to Tunned Performance for providing the final hint.
It was the 4 wire connector in the ICM, it was bad.
Thanks everybody!
Thanks everybody!
