Deleted evap canister now tank line leaks gas!
Car: 85' Firebird TransAm
Engine: 305ci TPI 5.0L
Axle/Gears: Posi 9 bolt differential 3.27
Today I took off the evap can and installed a home made cold air/ in fender intake mod, the mod was a success as I used the convenient square cut out that is located behind the canister. So I did some research here and a lot of people have said to cap off the 2 lines ( I did ) and either cap or put a fuel filter in place of the bigger gas tank line. Well I put a piece of cloth towel and stuffed it in there and took it for a 15 min spin. When I came back I checked the line and the cloth was SOAKED in gas.. I noticed my mpg dropped a tad or maybe I was being more heavy footed? My concern is, there any way to prevent the line from leaking out like this???
Re: Deleted evap canister now tank line leaks gas!
I tried an inline fuel filter on the gas line and it seemed to have stopped the leak, I routed it in the fender wall where the pod filter now resides to reduce the hint of gasoline fumes, which aren't that bad really. Im sure on a hotter day it may be more pronounced.
Evap lines should only be carrying fumes...unsure why a filter would stop your issue? As it is a blow through device.
Best recheck what you did...gas makes a big boom...people die.
I understand the filter is a blow through device, but its designed to contain and stay soaked with gas IF the event occurs again. It hasn't so far. Why gas came through the line? I cant say, which is why I came here for an answer in the least an idea.
Engine: 4++,350 & 305 CIs
Y not hook the canister back up but hide it up behind the bumper support like i did in the early 90s.
Ive seen pics of it being bolted up upside down under there is that what you mean?
i just moved mine to hiding it the best i could under the tiny overhand at the front passenger corner of the engine bay. I have heard some people having issues after putting it upside down, and also heard of someone having some issues after extending the vacuum lines. basically i left my line length the same but tried to hide it a bit.
The wont work like they are supposed to if upside down.
The SLP kit comes with longer vac lines and electrical to move it across the engine bay. I havent had any problems with my lines being longer.
Originally Posted by Voltz77
Why gas came through the line? I cant say, which is why I came here for an answer in the least an idea...
Appreciate the feedback guys,
1 Post
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
TPI's were designed to have the gas tank run at 2 psi positive pressure. I think this was to help the pump. There is a check valve in the vent line just before the Charcoal Canister, which opens only when the pressure exceeds 2 psi. You should be getting only fumes through that line, so the idea of the other relief valve being plugged is a viable one.
I would re-install it if at all possible. It is a safety issue being removed. Remember, it is gasoline vapors that explode, not liquid. Using it causes no loss in performance, and in fact returns the gas vapors to the intake ( increasing mileage (infinitesimally).
1992 Trans Am
05-10-2023 07:19 PM
AkDrifted
08-17-2015 07:45 PM
