411 injector sizing
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
I have bench run my motor after the swap and I'm wondering if I went too big on the injector size. BoschIII 24LB/HR. I have the pressure set at 38psi and it starts and runs but seems over fueled. No tuning software yet, stock tune. Not much past a stock build. Since the vans are rated at 19lb/hr, did I over do it? I have a set of 19/lbs that were in use at the time. Should j just swap them over till I can tune?
Not sure if it can be seen
355 decked block shop paperwork says 10.2:1
Afr 195 heads
Lunati 10120702lk (summit mag) cam with 1.6 Harland sharp
Afr 195 heads
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: 411 injector sizing
I'm running the bosch/svo 24# injectors in my 0411 conversion at 45# and it runs fine.
Engine: LB9
Axle/Gears: 3.55
Can't remember exactly, but I cranked my flow from 29 something to 32 something.
That was couple years ago, and I don't have computer with files on it right now.
I remember it was about 7%, and engine ran great with the 24#.
Car: 91 formula ws6
Transmission: 4l60E
I think mines at 38 psi idling with boschIII 24/lb hr injectors. It idles and revs OK but seems doggish. Fully stock tune...
92projectcamaro
01-18-2016 08:00 AM
toronto formula
11-10-2015 06:17 AM
knight72
08-10-2015 09:32 PM
