Has anyone done a L98 cam into a LT1?
Old 01-10-2015, 06:46 PM
sikpupy's Avatar
I am mesmerized by the off the line pull the L98 has and I want to marry that into a good breathing engine with the LT1. I know I can use the stock LT1 cam or a plethora of aftermarket cams, but, I hear plenty of stories how the L98 beats them off the line every time, and, that's the cam I am interested in.
Anyone try it for shts n giggles to see what would happen?
Old 01-10-2015, 08:27 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Has anyone done a L98 cam into a LT1?
L98 cam lacks the dowel drive required on an LT1. Long runner intake pipes aid L98 in producing low end torque, it's not just the cam.
Old 01-11-2015, 10:50 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
You could try the B-Body LT1 cam. It is designed for more low end torque, as it had to get a heavy Caprice moving. It's about the same came as used in the L31 vortec truck engine, which I am using. I had the higher performance LT1 cam in my L69, and was going to put that in the L31, but decided to leave the torque cam installed. So far, I have liked it. "light em up" any time I want!
Old 01-11-2015, 11:25 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The cams are so close in numbers id bet you couldn't measure a 2hp 2lbft of tq difference, maybe 5 each if lucky.
Its the intakes that are making 99% of the difference in the power band.
Old 01-11-2015, 06:09 PM
sikpupy's Avatar
I am actually looking at a caprice engine as we speak. Will probably switch over to aluminum heads before dropping it in, but, if the cam is already in there, sweet!!
Can always drill for a pin. I know the runners have some play, but, a cam is what determines the engines powerband. If your saying both cams are tuned to make the same power at the same RPMs, then yes, it is a moot point.
Interesting note about the cams. If its all about the runners giving the off the line advantage, do I stick with the L98 since it is going into my truck? Its not doing ANY racing.
Old 01-11-2015, 06:53 PM
TTOP350's Avatar
And about the pin length, all you do is pull it out a bit or push it in a bit. Again, its really not a big deal.
I put a super modded tpi on a tbi truck a loooong time ago and it was a pulling monster.
lt500r55
09-01-2021 01:30 PM
midge54
12-27-2019 04:14 PM
italiano67
08-31-2015 06:04 PM
midge54
08-29-2015 09:51 PM
TheExaminer
08-19-2015 10:07 PM
Quick Reply: Has anyone done a L98 cam into a LT1?
