Fuel pump survey
Car: 1987Iroc
Engine: 5.7
Fuel pump survey
Hello I am going to be replacing the fuel pump and starting a restoration on a roller 1986 sport coupe with a 2.8 v6 MFI. got the car as a roller I will be installing a v8 have not made a exact decision yet but my core question is what brand of in tank fuel pump should I replace the stock unit with? I have heard many bad experiences with certain brands. I have used Carter,Ac delco and Standard Motor products in the past with no problems but reading many threads about reboxed parts name brands quality slipping badly so I am little gun shy. I would to drop the fuel tank just once. To me its not the most fun job. So I am just throwing this out there. Thanks for your input.
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
Re: Fuel pump survey
I would have to say ac delco or Delphi I've used both with no problems.i'd stay away from carter and airtex. Just my
Engine: 4++,350 & 305 CIs
I use racetronix (walbro)stuff
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
I bought a Walbro high output pump for my bird.... it lasted about a year..... given that changing the pump is a pretty significant ordeal, I didn't want to be doing that once a year.... So, got a new sending unit, (had to modify mine for the walbro) new GM pump, put that in there, and no further problems.
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
