Spark when testing but not cranking
when grounding/ungrounding the white wire I get spark from the ignition coil. if I crank the engine I get no spark from the ignition coil.
I have a tpi swapped in my 240sx, no vats, msd 6btm, msd street fire coil, jegs replacement distributor with Accel ignition control module. the car has been sitting for a year and luckily my battery was disconnected and the Odyssey battery is still good...no spark though
I followed the MSD diagnosis to test for spark by grounding the white wire and I get spark, then no spark when cranking...
I have had two ignition control module's fail. first the one in the jegs distributor, then the original from the gm distributor. I don't remember if I should get spark when testing with the white wire when the icm has gone bad.
Last edited by 540sx; 03-24-2015 at 03:28 PM. Reason: new information I found made a statement inaccurate in my post
Re: Spark when testing but not cranking
just found some info I will try soon to test the pickup coil, I have checked for 12 volts on the pink and white wire, I am getting over 11 volts on both.
icm tested good at autozone although I had to help the guy test the part he was not grounding it properly and tried telling me the part was bad. after I had him move the ground to the proper bolt hole it passed. pick up coil has .950 oms. everything was checking out. I very carefully put everything back nice and tight(connectors, bolts, etc.) fired right up. I am thinking that either the two prong connector from ignition to ICM was loose, the the pickup coil connector to icm, or the ground on the icm. I have the accel ICM and the bolt that grounds it has a bit of raise where the bolt goes through. compared to the metal surrounding the whole for the bolt to connect with for the ground. I have used two small washers stepped in size to make sure I am getting a proper connection there since that was a problem before. I think I had the washers in the wrong order so I was not getting a good connection.
works great now.
works great now.
Hotrodboba400
12-10-2019 07:07 PM
New2Chevy
09-28-2015 12:35 AM
