Problem with the Holley 512-501
Any body else running into a problem with the Holley 512-501 fuel pressure regulator (pic is of regulator) hitting bottom of the upper plenum? I can't turn the dial to adjust the fuel pressure the plenum seems like it sitting on top of it not letting me turn the dial. Thanks in advance
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: Problem with the Holley 512-501
Yes, I had the same problem when I installed the Holley FPR. I had to remove the plenum and use my die grinder to remove some material from the bottom of the plenum. Be careful not to go too far. When I got it all back together, had plenty of clearance with the plenum. But the darn Holley FPR leaked. Holley said it was a bad diaphragm. So I switched to another brand AFPR. Good luck.
Thanks Fred SS I guess I'm going to have to get the old die grinder out and put it to some use. Daaang I haven't ran mine yet so I'm hoping Holley FPR doesn't leak but if it does any recommendation as to what brand would be good use? Thanks in advance!!!
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I've used that Holley regulator with no problem. Is it possible that those aftermarket runners locate the plenum smidge lower than stock?
COTM Editor
i have used these holley fpr on several of my camaros without issue... all with stock runners
Transmission: 2004r
TXwildman, the issue I had with the leaking Holley AFPR was about 3 years ago. I would hope Holley solved the problem by now. As evidence by comments from other members, it would appear that they have. The clearance issue was with stock runners. Eventually, I went with a TPiS AFPR. Difficult to adjust, but I don't need to get to it often. Let us know how it turns out.
BlackphantomZ28
08-22-2015 01:00 PM
86IROC112
08-17-2015 02:00 PM
