Throttle body gasket question...
Car: 1986 IROC Z
My gasket kit came with both of these gaskets and if my memory serves me correctly when I took it apart there were two gaskets between the TB and the plenum. Am I supposed to install both of these??
Just want to make sure before I put her together, Thanks!
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: Throttle body gasket question...
The bottom gasket is for early throttle bodies. The top gasket is for later throttle bodies. Use one or the other, not both.
IIRC, the top gasket is used with '88-'92 throttle bodies. The bottom gasket is used with '85-'87 throttle bodies.
1992 Trans Am
05-10-2023 07:19 PM
mdtoren
08-16-2015 05:45 PM
