Help needed quickly
Car: Camaro
Help needed quickly
Hi I have a problem I have put a 86 tpi engine in a 83 firebird that had carbed V6 and having trouble finishing off the wiring on the c207 connector. I have the pin outs but could do with a clear wiring diagram to know which wires I have to connect. Engine seems to run fine but when a little warm starts to idle a bit rough and just wanted to make sure this isn't anything to do with it. Any help would be appreciated
Re: Help needed quickly
A - BRN, ALDL “C” to A.I.R. Valve
B - ORG (& RED/BLK) Fuel Pump Relay NC & ALDL “G”
C - BRN/WHT, “Check Engine” lamp to ECM
D - LT BLU (& WHT) Fuel Pump Power
E - WHT/BLK, ALDL “B”
F - PNK/BLK, Engine Control Fuse to ECM, ESC
G - BLK/PNK (& PNK/BLK) GAGESFuse to Engine Sensors
H - TAN/BLK, ALDL “F”
J - ORG, ALDL “E”
K - BRN, VSS Signal to ECM
L - Not Used
M - BLK/WHT, Chassis Ground
N -
P - PPL, Brake Pedal Switch to TCC Solenoid
R - PPL/WHT (& PPL) CRANK Fuse to Cold Start Injector
J - ORG, ALDL “E”
L - Not Used
N -
