horrible idle
horrible idle
need some help guys
i have a 90 iroc z with the 305 when i bought it it ran horrible black smoke rich all the time ,cleaned the iac and it got better but not good
so here is what i have done
replaced the injectors to 19lb bosch 3 , new fuel press regulator, tpi gaskets , cold temp switch under the intake , new iac valve ,deleted the egr , no cat ,installed hooker shorty headers , removed air pump, car has new plugs /wires . coil cap and rotor
it runs good after warmed up but extremely rich and will not idle until warm
i need some guidance this is my first tpi car and i want to correct the issue so i can enjoy it
thanks in advance
thanks in advance
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: horrible idle
Did you check the coolant temp sensor at the front of the intake manifold?
