Pushrods for L98 with AFR heads?
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
Did some searches with mixed results. Do I use my stock 7.2" pushrods or, do I get new, after-market of the same size? OR do I get bigger ones? I am running same cam and intake but i'm bolting on the AFR 180cc heads with a 1.6 RR. Any brands or best bang for the buck ideas would be appreciated. I'm already over budget.. This whole thing started as an alternator swap.. you know how it goes.
Re: Pushrods for L98 with AFR heads?
Pistons are still .020-.025 in the hole on stock block and gm i believe used a .015 shim type gasket stock, so goin to a .041" is .026 higher. Pushrod assuming head geometry and valve hieghts remain the same as oem heads you would expext needing .026 longer in general
Car: 1991 Z28
Engine: 5.7 TPI L98
Thanks for the good info. The instructions say I need to use bolts with washers to prevent galling. Should I just spend the money and get all new ARP fasteners with washers? I'm also going to need some 1.6 roller rockers. Any advice there on best bang for the buck? Thanks again!
Car: 1991 Z28
Engine: 5.7 TPI L98
Ok cool. Thanks for all the info and patience for my questions. This is new territory for me and there is almost too much information when I Google stuff.
evilstuie
01-09-2020 08:29 PM
gixxer92
09-01-2015 04:32 PM
