Where to find saginaw female 16mm o-ring crimp fitting?
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: Where to find saginaw female 16mm o-ring crimp fitting?
If your talking about the fuel line O-rings, the last time I bought those, I got them from Rock Auto.
Saginaw and 16mm.....I think he's looking for a steering gear fitting.
A local hydraulic shop should be able to help you.
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
fuel line fitting. im trying to remake the rubber pressure line that attaches the tank hardline to the main feed line.
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
i accidentally bumped a really old thread..oops..
to be more specific... the fitting has to be a female 16mm x 1.5mm thread o-ring face seal 3/8" id crimp fitting.
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
think this one will this one work?
http://www.grainger.com/product/EATON-AEROQUIP-Fitting-16P819?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/16P816_AW01?$smthumb$
1A8DL6 aeroquip part number.
You're probably going to have to get adapter fittings (Earl's) to convert the male o-ring hard line to either a male or female AN. That way you can use easy to find hose ends.
http://www.summitracing.com/parts/EAR-9894DBJERL/
Again, have you tried a local hydraulic shop? They should be able to help you or at least be able to tell you if the end you're looking for is available or not.
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Unless I'm missing something, the spec's for that fitting don't specify that it's an o-ring connection.
http://www.hydraulicsdirect.com/ORFS..._p/p43-ffx.htm this might work but it doesnt tell me what thread it is
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
:sigh: turns out my ignorance is finally lifted. GM used power steering fittings throughout the fuel system and that is what I need.
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
found this:
http://www.diy-efi.org/gmecm/compone..._fittings.html
GM 10114709 3/8" feed hose, 1 female x 1 female Saginaw connector
found this:
Unless you find NOS hoses the wrecking yard is most likely the only other source.
FWIW when searching the bone yards, this same hose (as well as the return hose) was used on 1990 W-Bodies with 3.1L V6 push rod engines (LH0/VIN T).
I don't have a complete GM parts list by application so these hoses might have also been used elsewhere. I would guess that some J-Bodies with 3.1L V6 push rod engines might have used the same hoses.
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Are you now looking for the hose assembly and not just the fittings?
ambainb
04-25-2016 09:21 PM
