Will stock valve covers fit AFR 180cc heads?
Old 08-01-2015, 08:34 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
Im installing some AFR 180 eliminator (0919) heads with some 1.6 comp roller rockers. Will I need new valve covers for clearance? I haven't installed the RR's yet. when I test fitted the covers (without gasket) the center bolts seemed to bottom out too soon. No big deal to shorten the bolts, but now I foresee other potential problems. Is there a way I can modify the stock valve covers if there is fitment issue?
Im sure someone has gone thru this issue before. Thanks for any info!
Old 08-01-2015, 09:26 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: Will stock valve covers fit AFR 180cc heads?
I have perimeter bolt valve covers and I use extra thick valve cover gaskets. For center bolt valve covers, extra thick gaskets may be available. Check Summit or Jegs.
NBrehm
08-25-2015 11:49 PM
db057
08-22-2015 08:17 PM
Street Lethal
08-12-2015 11:33 AM
89mulletbird
Southern California Area
08-10-2015 10:16 AM
mustangman65_79
08-08-2015 01:18 AM
Quick Reply: Will stock valve covers fit AFR 180cc heads?
