MAP sensor terminal
Car: 1991 Z28 Convertible
Engine: LB9
MAP sensor terminal
Hey guys does anyone know which weather pack plug is used on the map sensor? Looks similar to the one on the TPS but is "keyed" differently. I broke the tab that locks it on to the MAP sensor and need to replace it. Any part nubers or links are greatly appreciated thanks
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: MAP sensor terminal
Google'd TPI MAP sensor pigtail
Take your pick... The middle two links show (correct?) colored wires.
http://www.ebay.com/itm/like/261801851226?ul_noapp=true&chn=ps&lpid=82
http://www.ebay.com/itm/MAP-Sensor-C...-/151403313601
http://www.obdinnovations.com/gm-1-b...1-tpi-engines/
http://www.hawksthirdgenparts.com/ma...7-tbi-tpi-lt1/
Car: '91 Firebird Formula
Engine: SP383 Deluxe FIRST® TPI Intake
Transmission: Tremec T56
Axle/Gears: Moser 9" Eaton Truetrac Motive 3.89
