injector part #
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
injector part #
Hello. I have a 87 iroc tpi car originally a 305 lb9 now that has a 87 formula or gta 350 in it by the code. My question is does anyone know the part # for 19 and 22 lb factory injectors. I want to see what injector is in it. I'm getting the car back Friday and want to see whats in there so I can have a chip done. I've tried searching and no good. Thanks Chris
I'm slightly confused by your information. Your 87 camaro has 87 firebird 350 in it, correct? If that's 100% correct then the injectors are 22lb as long as they used the 350's injectors. If the camaro was an original 305 tpi car and they reused the 305 injectors they'll be 19lb. Without part numbers we'll never be able to tell you for sure.
Re: injector part #
Sorry I was in a rush at work. The car was a lb9 305 car and now has a 87 350 in it. I checked the suffix code. I want to have a chip done so I need to find out what injectors are in there. 28 years later god knows what injector is in the car...
Re: injector part #
I will I have the car in the shop ill check friday
