LB9 hard start when cold
Old 09-02-2015, 01:27 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
The car has a code for low voltage at fuel pump and code 41 for the ESC. The engine and transmission were removed from another car, ran and started perfectly in that one. The fuel pump voltage is always between 12.7 and 13.1. Initially I thought that the ECM or memcal was bad in this car but I tried replacing both with known good ones that I had lying around. I'm at a loss here.
Orr89RocZ
04-25-2016 08:28 AM
Bryan F
08-18-2015 02:28 PM
cstrobel65
08-15-2015 10:19 AM
drathaar907
08-06-2015 04:20 PM
Quick Reply: LB9 hard start when cold
