TPI Oil cooler snap ring
Car: 1989 Formula 350
Axle/Gears: 3:23
Does anyone know what the snap ring on top of the oil feed tube that goes through the oil cooler actually does? As far as I can tell it does not have a groove to fit and just keeps the tube from falling in the event you unscrew the tube with the oil filter.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: TPI Oil cooler snap ring
I wondered the same thing when I had it apart. The snap ring has no function, it was likely just used to make assembly easier when new.
Engine: 4++,350 & 305 CIs
You guys have it figured out.
ambainb
04-25-2016 09:21 PM
toronto formula
11-10-2015 06:17 AM
Navy8125
08-21-2015 09:32 AM
Sanjay
08-12-2015 03:41 PM
