Injectors
Injectors
Are these any good as a replacement for a stock Firebird 350 V-8 1988..?
http://www.ebay.com/itm/252114274095
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Re: Injectors
Visit Southbay Fuel injectors and get the Bosch III injectors.
TPI should not have anything else but those. The ones pictured look like the factory multec injectors which are prone to failure and are absolute junk out of the box
Car: check
Engine: check
Transmission: check
Re: Injectors
RBob.
Re: Injectors
I stand corrected. I didn't carefully read where it says "Upgrade 4 Hole Bosch Injectors
" in the listing. A stock firebird with a 350 TPI needs a flow rate of 22 lbs.
Re: Injectors
There really is no difference between a 21 and 22lb injector. A small difference like that would never effect the perfomance of your car. Can these yellow tops be rated at 21lb? There is such a grey area when it comes to injectors. Depends on who flow tests them. We've been selling them as 19's for years, we will not sell them as 22's. If someone needs a 22lb injector we just recommend going with the bosch llls
Re: Injectors
These guys are the best in the business. I tried the Bosch III when I had TPI and loved the difference so much, when I converted to LS1 and got stuck with rusted injectors (which the seller neglected to tell me about), I talked to southbay and got the proper replacement. The engine has been happy ever since. (And so have I)
boardwell
Exterior Parts for Sale
10-27-2015 02:16 PM
1Aauto
Sponsored Vendors
10-02-2015 10:24 AM
