88 iroc 5.7 need help cranks got fuel and spark no start
i purcahsed a 88 5.7 iroc no start spray carb cleaner starts for a few seconds no fuel to fuel rail.so replaced fuel pump and strainer and fuel filter now got fuel at rail still no start any advice would appreciate.
thanks
adam
thanks
adam
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: 88 iroc 5.7 need help cranks got fuel and spark no start
Yes it will cause a no start. The shorted injector will not allow the ECM to pulse the injectors. Unplug the shorted injector and see what happens. You should probably get new injectors as the originals are probably all dirty anyway. Check the classifieds here at TGO or get a set of refurbished injectors from SouthBay, I read nothing but great praise of SouthBay from members who have dealt with them. GL!
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
Probably got bad injectors. Same thing happened to me. Fuel sat for awhile. Replaced everything fuel related except for the injectors and couldn't get it to start. They ohmed out properly as well. But were clogged up. They were the stock multecs. Put in some Bosch 3s and fired right up.
wanted to update you guys,well good news got it started,set the timing tp specs.all new injectors and fuel pressure reg and fuel pump,sending unit,fule filter,fired right up.and actually the 5spd works well converted from an auto since its a 5.7 car.now dont know if im gonna keep her and get repainted or sell the car.
Car: 1987 Trans am
Good news. Glad to hear it's up and running again and thanks for the update.
