code 12.will not start
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
driving car bout 15mph then it just shut off as if I turned the key off. no fire from coil. put new one on it still no fire. did the paper clip thing and it just keeps flashing code 12 over and over.
Car: '89 Chevrolet Camaro IROC-Z
Engine: LB9 305cid TPI
Transmission: TH700R4
Axle/Gears: 10-bolt, 3.42
Re: code 12.will not start
Code 12 is just ECM reporting in. It SHOULD always flash it. Try replacing the ignition module (it's inside the distributor, under the distributor cap).
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
I know. but it had code 32 stored and its not even showing up. just the 12. new module ddnt work. pick up coil maybe?
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
you didnt get the ICM from auto zone , did you ? i personally have gotten many ones from them , bad right out of the box. i go to oreilleys and get BWD select parts
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
put brand new duralast gold dist. in car. fired right up. but now when I put it in gear it dies. that and after bout a minute of warming up it starts messing up then comes out of it. still dies when put in gear though.
Blade09
12-27-2015 11:25 PM
kfsullivan
11-09-2015 07:49 AM
