temp gauge reads 10 degrees cooler than usual and engine startup rpm changed
we replaced a bad spark plug wire on 5.7 tpi rear passenger side #8 cylinder i think. we had to go under the car to connect it to the engine. its the one farthest back near exhaust passenger side. we had to replace the one next to it also. so the back 2 .
however in doing so i think trying to remove the old spark plug wire we accidentally pulled on some other electrical wires.
i checked and it everything appeared to be connected from bottom side.
i should take a pic next time i am under the car. cuz i dont know what the thing is te wires go to.
now when i crank car it used to have a cool choppy idle warmup like it had a cam and then when it warms up it mellows out.
now its mellow but it had a high idle until it warms up.
and then i noted the temp gauge seems to show about 10 degrees cooler than where it usually is.
so i am wondering if the wire we pulled was temp gauge related or what. maybe a ground wire.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: temp gauge reads 10 degrees cooler than usual and engine startup rpm changed
the wire for your temp gauge is a single green one . see to it that it isnt burned and well connected. also the sending unit often goes bad , as well as the gauge itself . both are available ,still. re check your work ,and report back
it made me wish i could hook up a scanner to the obd-1 port to see what the eng temp the computer see's. i can do this on obd2 cars w my smartphone but havent figured how on obd-1 cars yet if its even possible.
tks4 the info
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
the wire you pulled is your knock sensor, it goes into the ESC module which is behind the maf relays and fuel pump relay on the firewall
sjorgens
10-01-2015 07:54 PM
