Anyone know anything about this Throttle Body?
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
Re: Anyone know anything about this Throttle Body?
Stay away. Chinese made TB and the throttle plates are prone to getting stuck.
I have one on my trans am at the moment, works fine. quality isn't that bad, throttle shaft has zero play in it and it fixed the horrible idle I had due to worn throttle shaft bushings. BBK throttle bodies are by far the worst, I took a gamble with this throttle body and it ended up working out fine.
Thanks for the input. W the mixed reviews, I may stay away, especially if it can get stuck at WOT. Any ideas for a 52mm? Would like something polished but don't want to break the bank. Could polish on my own but there are alot of tight spots on the TB and it looks like alot of time consuming work.
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
I bought mine 58mm ~5 years ago,no complaints.I would use different gasket that come with that tb,it is very thin seal area at some places.
WildCard600 (02-26-2020)
Took me a minute to figure out what was going on here.. lol . I was actually looking into the same TB just recently, but its been discontinued, and everyone that had it has stopped selling it. Must have been some serious quality control issues.
The cheap TPI throttle bodies hit the scene too late in the game. They showed up just as the general public was junking thirdgens instead of modifying. Doesn't help that in most cases a larger TB doesn't actually do any good. Put the two together and the market wasn't there. Cheap Chinese quality control (or lack there-of) certainly didn't help.
Ran a 52 mm for yrs never had a problem.run a 58 mm now still no problems.know a bunch of guys that use professional products for tip to ls an they have never had issues with there stuff..
Had a bbk an had leaking issues an blades sticking have owned a number of bbk product an all where JUNK!!!!
IMissMy86TA
03-25-2016 10:52 AM
fkboatman
01-09-2016 04:58 PM
