Best cam for LB9 305 TPI.
Car: 1992 CAMARO Z28
Axle/Gears: 3.08
Hey guys I am about to get a chip programmed with the guys over at Custom Chip Inc and was wondering what cam that you had the best luck with for your TPI system. I have a 1992 LB9 305 TPI, 5 speed, with MAP. I have heard the Crane 2032 is good. Let me know what worked for you.
Thanks guys.
Thanks guys.
Car: 1992 Camaro Z28
Re: Best cam for LB9 305 TPI.
I don't have an LB9, but I've heard excellent things about the 2032 in those engines. Maybe not the best if you intend to go bat **** with the car later, but then again, if you do you probably won't be using the 305. 2032 should be great for your mild application, and cheap to boot.
Axle/Gears: 3.08
Specs;
I am seriously considering this cam but would have to upgrade to flat tappet lifters to.
Let me know what you think.
On a 92 engine? That should be a roller cam. Do not use a flat tappet cam in that. Big step back for no good reason. If I were sticking to a 305 and getting a comp cam, I'd use a 8-500-8. I don't believe in such thing as a "best cam". Just good/great cam for the right application and use. So there are many cams that will suit your engine.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I run a ZZ4 cam in my 89. 208 221 474 501 112
I had to install Comp Cam screw in studs and Comp Cams bee hive springs.
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
Thanks guys.
Thanks guys.
