Fuel rail mounted fuel pressure gauge
Old 04-08-2016, 07:35 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
I just wanted to share and to help out anyone looking for Parts and part numbers for a fuel rail mounted fuel pressure gauge.
JEGS Part Number: 555-41013
Fuel Pressure Gauge
0-100 psi
Black Dial
Stainless Steel Case & Bezel
JEGS Part Number: 361-923104
Aluminum AN to Pipe Adapter Fitting
-4AN Female to 1/8" NPT Male Swivel
90° Elbow
JEGS Part Number: 326-43050
Brass Coupling Fitting
1/8'' FNPT
Old 04-08-2016, 07:36 PM
91banditt2's Avatar
Engine: 5.7 HSR
Re: Fuel rail mounted fuel pressure gauge
Another
Old 04-16-2016, 03:58 PM
white88TA's Avatar
Car: 1988 Trans am 5.7 350
Transmission: Built 700R4
Axle/Gears: 3:73 posi
I did the same thing. Only thing is mine is getting zero pressure haha!!!.. I hate it. I can't seem to get any pressure to the rail.
Old 05-29-2016, 07:05 AM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
I forgot to ask before..... is there a thread sealant used, or just tighten it firm? Teflon tape?
Old 05-29-2016, 07:49 AM
91banditt2's Avatar
Engine: 5.7 HSR
I used Teflon tape on the gauge and the brass coupling but not on the schrader valve.
Old 06-08-2016, 09:01 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI + some bits
sweet thanks for sharing.
Old 06-08-2016, 11:21 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
+1
Old 06-09-2016, 09:30 PM
Engine: LB9 | LS1
after some reading regarding the teflon tape and fuel..... this is the way to go
Attached Thumbnails Fuel rail mounted fuel pressure gauge-41hfe7na6kl._ac_ul320_sr242-320_.jpg
Old 06-20-2018, 03:14 PM
kimnach's Avatar
Car: 1988 iroc-z (original owner)
Transmission: 5-speed manual
old thread, but in the quest to get my rebuilt engine running i decided to mount a FPG on the fuel rail. Bought the parts as suggested; however, the elbow (361-923104) does not have a provision to push the schrader pin in.....wrong part number?
Old 06-20-2018, 03:43 PM
TallTim's Avatar
Me thinks remove the schrader valve.
Old 06-20-2018, 03:57 PM
kimnach's Avatar
yes, i was thinking of that as an option.....just thought that perhaps there was an elbow with the pin depresser in it.
Old 06-20-2018, 04:08 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old 06-22-2018, 09:09 AM
BOTTLEDZ28's Avatar
Transmission: A4
Rail mounted gauges are notorious for failing. Been there, done that over the last 20 years. They are more suited for testing purposes only.
Old 07-09-2021, 11:20 AM
donnyhayes73's Avatar
Car: 1988 Firebird GTA
Engine: 5.7
Transmission: TH700
Did you determine why you hve no pressure. I'm having same issue suddenly. I hear pump prime and cut off, but test gauge shows like 2-3lb of pressure (if that).
Old 07-12-2021, 10:56 AM
Bill Chase's Avatar
Most gauge ports are a dash -3 /-4 (exact size escapes me at the moment) just use the elbow and go to local hardware store and get a jic cap for natural gas fittings. Any ace hardware will have a selection of it. 5 bucks or less.
However, for as cheap as 0-100 psi transducers are now days and gauges being so cheap. Just do an electric gauge and not have to mess with fuel getting dripped on the intake. Sensos have for better and cheaper. Added benefit is if your ecu has an extra 0-5 volt sensor input that's scalable you can data log it when tuning. Pretty sure the 7727 does. Can't speak for the f body ecus
Old 08-11-2021, 10:54 AM
C305's Avatar
Car: 91 camaro vert
Engine: 350,113heads,ccxfi260, slp shortys
Axle/Gears: 3.23s posi discs
Nice simple setup and the good thing is if there's any issues you can remove it all and re install the Schrader valve into original fitting. I haven't ran mine yet but I used the same setup.
The following 2 users liked this post by C305:
91banditt2 (11-07-2021), ZZ42Fast (08-13-2021)
89TA WS6
04-20-2016 09:37 AM
erik69&85
04-03-2016 01:33 PM
oners2nv
04-02-2016 08:51 PM
89TA WS6
04-01-2016 09:40 PM
edwardk12687
Carburetors
03-17-2016 03:43 PM
Quick Reply: Fuel rail mounted fuel pressure gauge
