Tpi problems loss ofpower
Old 04-18-2016, 11:23 AM
85iroc1971's Avatar
I have a 85 iroc Lb9 I can drive one day runs fine then the check engine light comes on I go to pass a car push the pedal to the floor I loose engine power it drops about 500 rpm and losses speed I don't have a code reader that is the next thing I am getting as it is an ODB1 plug and my ODB2 don't fit i let up on the gas pedal and it runs smooth again I turn the car off let it sit for 5 to 10 min start the car it runs fine 10 to 15 min down the road it starts again I would like to keep the tpi but if I can't figure it out will go to a carb need help and how do u read the codes with out a code reader since for me to get on is over an hr a way
Old 04-18-2016, 03:59 PM
Evanslooten's Avatar
Car: 1989 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.27 Posi
Re: Tpi problems loss ofpower
You can read the codes with a paperclip!
http://www.bnb32.com/camaro/check-er...maro-firebird/
THIRDGEN87
Interior Parts Wanted
08-24-2023 01:01 PM
Bowtieman1970
08-17-2016 02:50 AM
acerulz
Carburetors
03-30-2016 09:04 AM
sdmf1383
Carburetors
03-28-2016 08:45 PM
navy02ws6
03-25-2016 09:33 AM
Quick Reply: Tpi problems loss ofpower
