Need help. Car runs rough and misses in drive
Okay i have a 87 iroc- z. I'm not sure weather it's a 305 or a 350. But it idles high in park and then slowly will come down to normal. And when I go into gear reverse or drive it starts missing and running really rough. I just replaced the cap, rotor wires and plugs. I set the timing where it needs to be. When I get in the high Rpms there what sounds like a loud vibrating noise from the engine. It is TPI also it kinda head tastes if I give it just a little gas in drive. There is no check engine light on and I checked any codes and it only gives me 12 witch iv read is all normal.
Re: Need help. Car runs rough and misses in drive
there are also ways to test the pump and rest of fuel system but IMO it doesnt seem to be your problem.
