1986 tpi starts but doesn't keep running
Can't keep my eng running fuel spraying out of fuel rail when tapis removed and key off.took pic of pressure reg to show ht I found.Does it look bad??
Has cracks but not through
Re: 1986 tpi starts but doesn't keep running
Although the valve disc appears to have some deformation/erosion, the bigger problem is that the diaphragm is delaminating and possibly on the verge of failure. Replace the diaphragm assembly at the least, or risk constant flooding and potential fire if the vacuum hose to the regulator also fails.
Redcreekauto
06-21-2016 05:29 PM
gt4373
04-21-2016 11:09 PM
